Anti-theft system reset. Need help ASAP please.
Old Oct 8, 2011 | 10:26 AM
Ben76251's Avatar
Default Anti-theft system reset. Need help ASAP please.
hi guys,
So I have a 1996 civic DX, and I managed to set off the theft deterent system when I disconnected my battery. I don't know why it would do this, but it did. Basically when I reconnected the battery the hazard lights, dash illumination light, and some little red light to the left of the steering wheel, started flashing. There was also a beeping coming from the dashboard.
Does anyone know how to reset this so that it's back to normal? The car has all manual locks, and no fab/keyless remote. It's funny because I specifically bought this car as basic as I could to avoid problems like these, and here we are. lol
Also, it has an after market sony head unit in it. Could this have anything to do with this? Perhaps some anti-theft device in this? I know these 6th gen civics had a problem where if you removed the stock head unit the car would basically "shut down" it.
Thanks
Old Oct 8, 2011 | 10:33 AM
virgineg6's Avatar
Default Re: Anti-theft system reset. Need help ASAP please.
The only thing the radio has to do with the alarm, is that the alarm was installed so they wouldnt steal the radio. What are you talking about the car would shut down if you remove the head unit?
Old Oct 8, 2011 | 10:46 AM
grumblemarc's Avatar
The Grumpiest
I think some aftermarket decks had some sort of rudimentary anti-theft features.
Old Oct 8, 2011 | 11:27 AM
Ben76251's Avatar
Basically i'm just trying to figure out how to override/reset the stock non-keyless security system that the car has.
Old Oct 8, 2011 | 11:42 AM
motegicivic's Avatar
Take a pic of the light, the DX's did not have accessory alarms, only the EX's did.
You might have an aftermarket alarm.
Old Oct 8, 2011 | 01:21 PM
virgineg6's Avatar
Probably aftermarket alarm system, under the dash near the steering column there should be a little black box with a bunch of wires running to, take a picture and post it. The brand should be on it.
Old Oct 8, 2011 | 08:13 PM
Ben76251's Avatar
Right on virgineg6 and motegicivic.....
Alright, well I figured it out. Apparently someone installed an aftermarket alarm system on it (which I will be taking to the shooting range), so I ripped it out. The car was "functional" again, but wouldn't start still. I pulled apart the distributor and replaced the ignition coil, and all is well. Thanks for the replies. I just thought i'd let you guys know incase someone else is having a similiar problem.
Old Oct 8, 2011 | 11:19 PM
Confused why pull apart the distributor, the coil is separate?
Old Mar 12, 2016 | 09:45 AM
Michael Schultz's Avatar
A 2000 CRV has no injector pulse after changing distributer
Old Mar 12, 2016 | 03:19 PM
Former User's Avatar
Create your own thread in the CRV forum.
MemphisMax
17
Nov 7, 2016 06:13 AM
kishorvalji
Honda Civic (2006 - 2015)
May 30, 2013 08:20 PM
Bobby01
Jan 12, 2012 07:18 PM
Balltongue0077
Dec 15, 2008 09:37 PM
TunerShark
Jan 28, 2007 04:52 PM
