88-91 Honda civic disc brake conversion
Old Oct 8, 2011 | 07:33 AM
ef.91's Avatar
Icon2 88-91 Honda civic disc brake conversion
I'm new to Honda-tech. I have been searching for specifics on doing a rear and possibly front disc brake conversion on my 1991 Honda civic sedan.
I have heard that if you do the rears you have to do the fronts as well because the rears are bigger than civic fronts. I am curious if I will need custom brake lines and about what car I can get them from. I've heard any integras will do. I have also heard that the brake booster has to be changed! Idk! Someone please give me some good info! I am ready for this conversion! Thanks!
Old Oct 8, 2011 | 08:59 AM
alex14's Avatar
Default Re: 88-91 Honda civic disc brake conversion
This should help you out.
https://honda-tech.com/search.php
Old Oct 8, 2011 | 10:15 PM
ef.91's Avatar
Thank you for the info. Helped alot
Old Oct 8, 2011 | 11:56 PM
EL Vap133's Avatar
When you go with rear disc brakes, you do not "have to" go with bigger front brakes. IMO, it is better to change them all at once (including MC/BB) because then you don't have to bleed the brakes all over again.
Old Oct 11, 2011 | 05:54 PM
ef.91's Avatar
Cool think I pretty much figured it out
Rear Disc Conversion
1. 93-97 delsol or 94-01 integra or 99-00 Si or "some" 92-95 Civic Si trailing arm assembly.
2. delsol/Si rear brake lines (if you use integra trailing arms/calipers you need INTEGRA brake lines...they have a COMPLETELY different caliper attachment that WILL NOT work with delsol/si calipers).
3. 99-00 Si Emergency brake lines (integra lines will work but they come together into a single rubber floorpan grommet which you'll have to hack up and you could hear wind noise, etc under the carpet).
4. 99-00 Si Master cylinder/proportioning valve (you can go with integra parts but you'll have to flare lines, etc) the Si stuff is drop in.
Old Oct 12, 2011 | 03:23 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What car were you working on again? I think you are confused...
Old Oct 12, 2011 | 05:58 AM
Charlie Moua's Avatar
yeah i think your confused with EG/EK...
for your ef sedan this is what you NEEEEEEED:
1) 90-00 integra rear trailing arms complete with rotor, caliper, brackets
or
90-91 crx si ones OR 92-95 civic ex sedan ones
2) 90-93 integra sedan OR coupe ebrake cables ..... all other ones will be too short.
Some people say you can use 94-00 ebrake cables but i tried and it's about 1" too short unless you don't plan on mounting the cable lines in stock location.
What you could do as optional:
3) upgrade your sedan MC to EF EX sedan 15/16 MC....
if your not tracking your car I would tell you to not worry about upgrading the BB unless it's broken.
4) 4040 ppv from 90-93 integra RS or LS(non-abs) bolts up to stock ef ppv and has same flare lines as your civic
5) upgrade front:
really all you need is a better brake pad.
but if you realllllllllly want tou upgrade you can do this
- use stock knuckle
- get any 90-00 civic EX/SI rotor OR 90-00 integra NON ITR rotor... they are 10.3" compared to your 9.4" rotor.
- go to autozone and order new acura legend calipers and brackets
- get itr brake pads (same size as legend)
- go to hardward store and get some washwers... you'll need to stack probably 2 washers behind each wheel stud and the placed the new 10.4" rotor OVER the washer/wheel stud.
- continue to install & bleed new brake calipers
enjoy....
Old Oct 13, 2011 | 11:22 PM
ef.91's Avatar
I rechecked the post that I found my info from and it said 92+
So you guys were right. Thanks for the good info
JHOT_Imports
138
Nov 30, 2008 06:49 AM
dew_fever
Apr 16, 2006 04:58 AM
ACURATSX
Mid-Atlantic (Sales)
Nov 18, 2005 03:26 PM
