EF wont rev over 3500
Old Oct 5, 2002 | 01:12 PM
brinks's Avatar
Default EF wont rev over 3500
This problem is on a friend's 90 ef sedan, all stock excep for I/E. The problem is that sometimes the car wont rev over 3500 rpm no matter how much throttle is given. Thimng nelt, plugs, dist. cap, rotor, are all fresh. Timing is ok. Could it be a problem with the ignitor?
Old Oct 5, 2002 | 01:14 PM
EF_LSVtec's Avatar
Default Re: EF wont rev over 3500 (brinks)
make sure all vacuum hoses are in order...and the timing belt if replaced was put on correctly.
Old Oct 5, 2002 | 01:23 PM
Urban Business
Guest
Posts: n/a
Default Re: EF wont rev over 3500 (EF_LSVtec)
could be throwing a code for the crank angle sensor, you prolly are. in that care you have to buy a new dizzy
Old Oct 5, 2002 | 02:11 PM
CimorelliCRX's Avatar
Default Re: EF wont rev over 3500 (TorteX)
I had this problem, but it was a sensor ont he intake manifold was on the wrong spot. I had 2 on backwards.. But I dunno if that could be the problem..
91EFHATCH-TECH
Feb 17, 2012 09:14 PM
krobie
13
Feb 14, 2010 12:24 PM
zcmotor
10
Feb 11, 2008 05:26 PM
legendboy
Nov 3, 2004 10:57 AM
