stripped 9-spline lug nut key and lug nuts
Old Oct 6, 2011 | 07:33 PM
F20Cdriver's Avatar
Icon2 stripped 9-spline lug nut key and lug nuts
i have a 9-spline lug nut set and my key is stripped. some lug nuts are stripped also. i called called or visited sears,discount tire, courtney tire, ab & t tires, wheel depot, fox tools, knova tools, autozone, kragen, carquest, and a bunch of other wheel and tire shops around my city, but i coulnt find anyone who knew how to take off my 9-spline lug nuts. i also browsed forums and searched youtube, but to no luck.
i would be tremendously appreciative if someone could help me find the solution to my problem. so far i have tried hammering in a 3/8 drive, hammering in a chisel and attaching a socket at the end of the chisel, and i have tried hammering a socket on the lug nut(nothing fits around the lug nut).
i humbly ask my fellow honda enthusiasts for help...please
Old Oct 7, 2011 | 04:25 AM
toyomatt84's Avatar
Sanji
Default Re: stripped 9-spline lug nut key and lug nuts
Have you applied any heat to the lug nuts to help get them to free up?
Old Oct 7, 2011 | 04:48 AM
cpl rampage's Avatar
And if heat doesn't work, you could weld on a nut to the top of them, depending on how much they stick out of the rim, you can do this on alot of OEM wheels, not so much on aftermarket tho.
Old Oct 7, 2011 | 05:16 AM
jdmcivicracer89's Avatar
Well if ut gonna trash em. I hammer on a slightly smaller socket and that usually gets em off but then u gotta nother lil fight wit it bein stuck in the socket. Nuttin a vice and screwdriver wit a hammer cant fix haha.
Old Oct 7, 2011 | 03:32 PM
F20Cdriver's Avatar
no, i havent done that yet. thank you very much for the tip. im not sure how ill complete that task without a blow tourch, but now i know that applying heat might do the trick.
wow, never thought to weld another piece to it, sounds like that would definately work. thanks for the tip.
yup, i hammered a t-60 hex into the lug nut. it was on there pretty tight, but my 3/8 extension snapped while trying to get it off and there is no room to turn it without using an extension. im begining to think that the previous owner had the wrong size lug nuts on the wheels, because they are way to hard to get off.
thanks for your help
KraZZyiE
Sep 22, 2011 08:31 AM
CIVICRicerBoy
Feb 19, 2009 10:08 AM
robble36
17
Feb 1, 2007 10:06 PM
