88m Crx rear Lca's = Itr Lca's?
I heard they are the same part number , and same physical structure. Has anyone heard of someone buying crx lca's for their 94 - 00 integ ? Plz help me out if you have any info on what i can do since the dealer in my area is on back order. Thanks
if memory serves me right, they are either the same or very similar. I believe the rear shocks for the 88 crx are the same as the ITRs, so i'm assuming the rear LCAs are the same . hope this helps
Tj
Tj
if my memory serves me correct, different part # but same part.
the ITR's have the spot for the ABS lines, if i'm not mistaken.
if you look up the part number for aftermarket shocks, the rear shocks will be the same as for '88 crx and '97-'98, '00-'01 ITR's.
88 CRX rear LCAs have the same design as the ITR LCAs.
Why would you want the 88 CRX rear LCAs over the ITR LCAs though?
Rear swaybars are nice things to have.
It's the same design, my 1990 EF9 uses the same type of shock as the ITR, and I remember someone using ITR LCA's on their EF as well
[Modified by Gump, 11:14 PM 10/6/2002]
they are similar design but they are not the same. if u line them up side by side u wil see that the holes for the bolts that go into the shocks are in a slightly different place, it will work but the geometry will be slightly different. this goes for all jdm ef and da rear lca;s. on the other hand, jdm eg rear lca;s line up the same as itr;s. u can tell the difference between a the two by lookin at the number of holes on the side of the lca, there are 3-4 i believe on the ef/da lcas while the itr and jdm eg are solid and only have the holes for the shock and sway bar bolts . hope this helps
bobbyg crxh22
Jan 24, 2007 06:25 PM
Speed PHreak
40
Apr 26, 2005 09:24 AM
