FS: Fully Built D16z6 Vitara Turbo block+PRECISION, ID1000, GO AUTOWORKS RAM HORN!!
So i saved all this money for my project and now i am going to college and need funds for school.
For faster response- 630-696-1618
MOTOR IS CAPABLE OF HANDLING 400HP.
*** $2000 OBO FOR JUST LONGBLOCK---> NO INTAKE MANIFOLD, THROTTLE BODY, VALVE COVER AND FUEL RAIL****
What you see listed is what you get.
NO LOW BALLERS
I have paperwork from my machinist who built it.
Bump if you view please.
Motor is very healthy and using Mobil 1 Fully synthethic 10w30. Motor has 7500 Miles in break in. Oil changed every 3000 miles. Does not burn any OIL.
Head- BRAND NEW OEM HONDA GASKETS
Ported and polished
Golden eagle block guard
Supertech Valve Springs and Retainers
Gasket matched
Hondata intake manifold gasket
5 angle valve job
Bisimoto Stage 3 Camshaft N/a
Bisimoto Cam gear
Bottom End-
Ycp Vitara Pistons, 7:5:1 Low compression
Tuner Toyz H Beam Rods
ARP ROD BOLTS
Ported z6 Pump
Tapped oil pan
ACL race bearings
ARP HEAD STUDS
Pics of the motor when i got it back from the machine shop
Im attending college right now, but need to pay off school right now. I lost interest and in need of money, I currently have no job right now. I am parting out my 96 project civic that i am going to regret but school is my first priority as of right now.
EVERY PART LISTED HAS 300 MILES ON IT AND IS BRAND NEW THAT I BOUGHT.
Go- Autoworks Ram Horn, 38mm Wastegate flange- $550.
Injector Dynamics 1000cc Injectors w/clips- $400-
Precision SC44 Turbo, NO SHAFT PLAY, BRAND NEW BASICALLY, IT WAS REBUILT BY PRECISION, I HAVE DOCUMENTATION.$750
Compressor Cover T04E 3" Inlet
Exhaust Housing T3
A/R .63
Exhaust Trim 63
I have a Speedfactory 4 bar Map sensor- $80
NO LOW BALLERS
Ported and polished
Gasket matched
5 angle valve job
Bisimoto Cam gear
Bottom End-
ARP ROD BOLTS
Ported z6 Pump
Tapped oil pan
ACL race bearings
ARP HEAD STUDS
Exhaust Housing T3
A/R .63
Exhaust Trim 63
xkrazyxjbrkerx75
Dec 2, 2011 10:38 PM
xkrazyxjbrkerx75
Oct 24, 2011 11:56 AM
xkrazyxjbrkerx75
Oct 9, 2011 07:52 AM
xkrazyxjbrkerx75
Sep 14, 2011 05:35 PM
