B1 vtec vs B2
Old Oct 6, 2011 | 10:08 AM
jksmith's Avatar
Default B1 vtec vs B2
What all parts are interchangeable?
Dizzy?
Alt?
Intake Manifold?
Heads?
Old Oct 6, 2011 | 10:35 PM
rival12's Avatar
Default Re: B1 vtec vs B2
Dizzy?
Alt?
Intake Manifold?
Heads?
Complete a search.
Alternator should be the same. Distributor should be the same. Head will be a Vtec Head with the B1, Vs. Non-Vtec B2... I think the manifold is similar, not sure if it's the same. Should be only the head, Ecu, wiring harness that's different.
Old Oct 7, 2011 | 04:11 AM
jksmith's Avatar
Originally Posted by rival12
Complete a search.
sorry was on my phone when i typed all that,
So can i put a B1 intake manifold on a B2 motor?
Old Oct 8, 2011 | 12:49 PM
CDelgado220's Avatar
https://honda-tech.com/forums/showth...angeable+parts
& Dizzy's are different
Old Oct 8, 2011 | 12:54 PM
Aradin's Avatar
Premium Member
Distributor is NOT the same.
F22B1 uses internal coil.
F22B2 uses external coil.
Old Oct 8, 2011 | 04:50 PM
gogydm's Avatar
What everyone before me said. Heads are different. Why would the alternators be different? Intake manifolds are the same.
Old Oct 9, 2011 | 04:27 AM
GhostAccord's Avatar
Alternators are different. However, they are interchangeable.
The B1 intake manifold will fit, watch out for the earlier manifolds with the FIA ports. Thy will cause vacuum leaks on the B2 if the ports aren't plugged up. There are no gains in using the B1 IM though. The F23 Intake and throttle body would be an upgrade. Requires a 2 wire IACV adapter plate.
Exhaust manifolds will fit however the B1 is a 4-2-1 manifold & down pipe setup. Where as the B2 is a 4-1 manifold & down pipe setup. Therefore you will need the manifold and down pipe from the B1.
Injectors and resistor box are interchangeable.
Block and internals are completely interchangeable. The balance shafts, oil pump housing, water pump, pistons, rods and crank are all the same.
Head is completely different......VTEC......
Power steering pump, Alt and A/C are all interchangeable. The B1 alt is a higher output
Distributor is not interchangeable.
That's all I can think of for now.
Old Oct 9, 2011 | 06:37 PM
nus_dogg's Avatar
x2 on what Ghost said!
NINE-ONE-CIVIC
Nov 4, 2012 08:10 PM
ClassicConcepts
Oct 8, 2008 08:52 AM
cowboys22cardinals22
May 23, 2008 04:39 AM
IrishSaint816
Jun 30, 2007 05:03 AM
mstewar
Nov 15, 2005 07:57 AM
