park is locked idk why??
OK I have a 1992 Honda accord with the h22 swap I just got the new tcu for it which was the p0n (it is auto) well after I swaped the tcus out the shifter is stuck in park unless you use the key to get it out so I have to start my car in N my? Here is why would it di this and is there a way to fix it bypass it? Thanks for any help
cody
cody
Does the brake lights come on? If not, then possibly the brake light switch under the driver side dash, next to brake pedal.
If not that, it may even be the TPS. See this thread for something kind of similar:
http://www.hondaaccordforum.com/foru...-help-7/page2/
Post back if you solve it, to possibly help others with a similar problem.
There is a lock solenoid in the console below the shifter. When the brake is depressed it is supposed to release the shifter so you can move it. You should hear it release when you press the brake the the key on. On other cars I've seen them gummed up with grime, spilled soda, etc.
Joetxstate
Mar 4, 2020 05:37 AM
asocallocal
Aug 29, 2010 07:00 PM
