Jdm b16 cable tranny issiue.. not able to put into gear very often.. Bad tranny? Gear
Old Oct 5, 2011 | 10:25 PM
88SeeOurEx's Avatar
Icon6 Jdm b16 cable tranny issiue.. not able to put into gear very often.. Bad tranny? Gear
Honda 1988 Crx Dx:
JDM GSR B18C longblock
JDM B16 Transmission... DA clutch cable
I've been noticing my transmission has been keeping me locked out of gears (shifting into a gear) for sometime and its gotten progressively worst to the point where i dont like to drive my crx. i'd have the clutch pedal all the way to the floor and go to put it into first and its like i dont have my foot on the clutch at all and it just wont go in. not even in 2nd, 3rd, 4th, 5th or even Reverse. but than theres times were its like nothing is wrong which gets annoying and makes me procrastinate even more cause "its not so bad' which is false.
Has anyone ever experienced this kind of issue with a cable tranny? Im not sure if my tranny is just going out, my gears are crap or anything else for that matter.
Ok so ive been debating on getting a new cable tranny all together or get a hydro tranny with the cable to hydro conversion Or just get this one rubuilt any suggestions/thoughts/ideas.. Thanks peeps
Old Oct 6, 2011 | 04:39 AM
ewok1's Avatar
Default Re: Jdm b16 cable tranny issiue.. not able to put into gear very often.. Bad tranny?
i had a similar problem on my b16,i swaped my b16 tranny and fot a gsr cable trans.Hoping the problem would be fixed it came back again, gears were hard to throw in especially. first gear,and i grinded every time when put into reverse! Come to find out it was may CLUTCH..got a new one and my gears go in like butter.I feel u on that annoying part, struggling with your gears is not fun on the streets.no bueno.
Old Oct 6, 2011 | 04:52 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Pressure plate, shift linkage, bushings, shift forks, among other things could be the culprit. Since you say it sometimes works and other times doesn't - I would lean more towards your linkage... hard to say since you haven't done any work yourself yet.
Old Oct 10, 2011 | 08:57 AM
88SeeOurEx's Avatar
This is definitely stress releiving to read that its possibly my clutch. i'd feel more comfrotable with that casue i been wanting to change out my pressure plate and clutch anyways.. Hope this helps me and thanks for your insight bro! guess ill be dropping my tranny and change it out over the weekend.. and again thanks!
Old Oct 10, 2011 | 09:00 AM
88SeeOurEx's Avatar
Thanks for your input bro.. i took a look at my linkage and bushings and both appeared to be fine. so im gonna have to check out my fork and look at my gears since im gonna take my tranny off over the weekend to replace the clutch and pressure plate
Old Oct 10, 2011 | 12:51 PM
ewok1's Avatar
let us know the outcome
Old Nov 23, 2011 | 10:48 AM
88SeeOurEx's Avatar
*Update
i know its super late but better late than never..
My clutch was almost gone but the culprit was my flywheel. it was gone so needless to say i got a new flywheel and my already purchased new clutch and pressure plate installed and it shifts like butter ..... thanks again for the replies and help Ewok and NevaEva
Old Nov 23, 2011 | 01:47 PM
ewok1's Avatar
good to hear bro!
Justef Datshiet
Jan 11, 2013 04:13 PM
CRX16T
Nov 7, 2004 07:34 PM
blueintegra90
Feb 11, 2004 01:12 PM
