91 Civic DX Distributor or SI???????? Dual Point to Multi Point???????
im doing a dual point to mutli point and i need to know if i can still use my dx distributor??or do i need to use an si?? thanks in advance
You need the HF or SI Diz. It has the 2 xtra wires for the Cyl Position sensor. The DX is only a 5 pin harness and the HF/SI are 7 pins. The Ecu will need to look for these sensors. I've done the swap b4 and have ran thru the ECU pins enough times if you need any help IM me and help you thru it. Its a easy swap if you pay attention closely to the wording.
Big Bang
14
Aug 22, 2003 06:18 AM
88rexdxa6ed
May 2, 2003 06:47 AM
Agent Daimon
Dec 17, 2002 03:42 AM
