Car will only rev to 4700 rpm then hits 2 step launch control in every gear
Old Oct 5, 2011 | 03:26 PM
EusebioSam19's Avatar
Default Car will only rev to 4700 rpm then hits 2 step launch control in every gear
Wth man I fix my car then I go to drive it & it'll only rev to 4700rpm then it just hits the launch control. Whats my culprit, wasn't doing this before
Old Oct 5, 2011 | 04:59 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Car will only rev to 4700 rpm then hits 2 step launch control in every gear
Sounds like limp mode. Check engine light on?
Old Oct 5, 2011 | 06:01 PM
98civdx's Avatar
Master Detailer
Does your speedo work?
Old Oct 5, 2011 | 06:31 PM
Speedo works
Old Oct 5, 2011 | 06:37 PM
deving916's Avatar
Old Oct 5, 2011 | 06:47 PM
hon2984's Avatar
I had an ECU go bad on me....did this except it was @ 3700rpm
Old Oct 5, 2011 | 07:54 PM
Cel is on gotta wait till tomorrow it poured rain today
Old Oct 5, 2011 | 07:55 PM
Spoolinls's Avatar
may be limp or speedo cable i had the same problem my speedo cable would come loose at 3k
Old Oct 5, 2011 | 07:58 PM
Which cable is the speedo cable? Do you mean the actual cables on the backside of the speedometer itself
Old Oct 5, 2011 | 08:19 PM
dk=gsr's Avatar
this happen to me too, but it was my thermo. was broken and would run cold all the time.
Old Oct 5, 2011 | 09:10 PM
Spoolinls's Avatar
The one on the trans
Old Oct 5, 2011 | 09:21 PM
10psiLsEf2's Avatar
yep sounds like limp mode. but if no cel.
then i would start pointing fingers on your vss(speed sensor)
Old Oct 5, 2011 | 09:52 PM
94eg!'s Avatar
#1 Super Guy
Loved
WTF are you guys talking about. 92+ Hondas don't have a speedo cable!
Since your CEL is on, then you know your ECU is in limp mode. If you want to know what the problem is, go dig up a paperclip and get back to us after you get the code...
Old Oct 6, 2011 | 07:17 PM
10psiLsEf2's Avatar
thats why i put (speed sensor)
Old Oct 6, 2011 | 08:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Yeah sorry... I wasn't directing that at you.
ImportsCRX
10
Oct 13, 2004 03:07 PM
ron b
Apr 29, 2004 10:49 AM
DOHCRX
Mar 28, 2003 08:22 PM
