Built B18B engine, and Turbo kit. 305hp, 320TQ. 127mph 1/4mile Ohio
I have a complete and rebuilt 300+ hp engine and turbo kit for your honda civic or acura integra.
Honda, Acura, B18B longblock. Non-Vtec but lots of torque!
Manly rods.
CP pistons
ACL bearings
ARP headstuds
Crower 402T turbo cams
Supertech valve springs, retainers and seats.
all new gaskets and seals
New Waterpump, oil pump, and timingbelt.
complete longblock ready to handle up to 450hp.
machine work and assembly done by slowmotion.
Custom turbo kit.
Spooling performance Custom manifold, setup for external wastegate.
SP 3" downpipe with wastegate recerculation.
Tial wastegate.
Borg Warner Turbo charger.
SP 500hp FMIC
2.5" intercooler piping, with T-clamps and silicon couplers.
HKS Super Seqencial blow off valve.
3" custom exhaust, will fit Civics and Integras. would also fit Del sols if you shorten it.
RC 680cc injectors
Custom 2stage boost controler solenoid controled by the computer.
Chiped ECU with the map from the car on the dyno. will just need a quick retune on the dyno. but won't require a full tuning season @ BIG 3 Racing.
High flow fuel rail
High flow adjustable external fuel pressure regulator.
Walbro 255 high flow fuel pump.
all oil lines and adapters.
Moroso 5qt oil pan, with fiting for turbo return line.
Boost gauge, EGT gauge, Oil PSI gauge, and a 3 pod pillar gauge cluster.
This engine is ready to drop in and go, everything you need is included, fuel, boost, exhaust, air filter.
we made like 305hp and 320tq on the dyno.
the car ran a 13.1 at 127mph. we had no traction at dragway 42. i would highly recomend an LSD for your trans, and traction bars, and i bet you could run low 12s with street tires. maybe even mid 11s on drag ets. this was with the LS transmission, we were getting great fuel milage aswell.
$4800 for everything.
$2800 for the engine and $2500 for the turbo setup.
I have videos of the car on the dyno!
Located in Wooster Ohio. I am willing to deliver anywhere in ohio for an aditional $275 or even to cabelas in wv. let me know where you are at and we can work something out.
Manly rods.
CP pistons
ACL bearings
ARP headstuds
Custom turbo kit.
Tial wastegate.
SP 500hp FMIC
RC 680cc injectors
High flow fuel rail
Last edited by Snail Tuning; Oct 5, 2011 at 03:13 PM. Reason: forgot to include location.
TWINK1E
May 7, 2013 01:33 PM
crispchris
Jul 18, 2009 03:56 PM
crispchris
Jul 18, 2009 12:07 PM
crispchris
Northern California (Sales)
13
Jul 18, 2009 12:06 PM
