CEL on no 2ndary 02 sensor ls help!
Old Oct 5, 2011 | 02:45 PM
r1paniccia's Avatar
Default CEL on no 2ndary 02 sensor ls help!
ok so i bought a 96 ek b16a2 swap p72ecu. car has a cel on for secondary 02 sensor. the primary is still hooked up, but there is no 2ndary hooked up, how do i hook this up ? do i have to tap into the ecu wires? there is a bung on the exhaust for a 2nd one just no were to plug it in! i really wanna get the cel off so i can pass inspection befor i turbo it. new york state is a pain in the butt with this! btw the prev owner gave me a 4 wire 02 sensor i just dont know where or what to do with it! any help is appreciated guys im clueless with this. i have searched and searched and cant come up with anything!
Old Oct 6, 2011 | 01:05 AM
r1paniccia's Avatar
Default Re: CEL on no 2ndary 02 sensor ls help!
cmon guys! I WANNA GET THIS CEL OFF SO I CAN PASS INSPECTION AND START THE TURBO INSTALL!!
Old Oct 6, 2011 | 01:19 AM
HondaPartsHero's Avatar
Technical Hero
You are going to need to get someone to weld an O2 bung in your exhaust after the cat or get a cat that has the bung in it. For the O2 wiring you will just need an extension harness (check my signature below if you need one) to connect the harness you described to the new O2 sensor . The best place to get a secondary O2 is Amazon, the Denso brand. Here is a link to the one you will want:
http://www.amazon.com/Denso-234-4065...7892675&sr=1-1
Old Oct 6, 2011 | 02:24 PM
r1paniccia's Avatar
i have heard of you befor! you come highly recomended from alot of boards! heard alot of good things about you and your harness's the exhasut is after market and DOES have a bung all ready! i do have a 02 sensor that came with the car previous owner included it, it does look a little diffrent onthe tip that goes in the bung but it is a 4 wire will it work? once i figure that out im ordering your harness, and also how do i wire it to my car since theres no existing wiring? THANKS FOR THE REPLY!
Old Oct 6, 2011 | 04:15 PM
motegicivic's Avatar
Are you sure there is not wiring? was it cut off and you do not see it? tucked into a harness somewhere? My point is a factory EK has to have it unless, your harness is different?
Old Oct 7, 2011 | 01:06 AM
r1paniccia's Avatar
previous owner that did the swap said he used a 96-98 ex harness i beleave if i remeber correctly?
offshore
16
Dec 13, 2011 03:37 PM
mustang5.slow
Jul 18, 2007 09:32 AM
C_Civic
11
Apr 20, 2004 07:34 PM
gsrvtechatch93
Mar 29, 2004 08:48 PM
