Putting jackstands on all 4 corners of EF?
Haven't really jacked up a car on all 4 corners before, but I'm painting my wheels so would like to throw my EF up on jackstands. all 4 corners. Okay, so 1st step is jack at rear tow point then place 2 jackstands under rear lift points, then what from there? there is the jack point to raise both sides at the front? Or..shall I do one side at a time?? Thanks guys.
i do front then rear, when the front goes up the rear is held by the ebrake. then the rear. the front wont move cause its off the ground. do the front from the middle of the cross member, you should see that lump.
Yep, do the front first, there is a bump under the rad support you can jack from there. Put the jack stands under the pinch weld, then jack up the rear from the tow hook.
Walterronny
Mar 19, 2016 11:30 AM
