si and dx transmission
gears 1 thru 5 on a DX are the same as an SI, whats different is the final drive. all the gears on the SI are a little shorter because of the shorter final drive. the DX tranny is for better gas milage because of the taller gears. the SI tranny is better for acceleration.
[Modified by Fast 1point5, 5:27 PM 10/5/2002]
i believe the si tranny has better acceleration, hf tranny is good fuel economy, and dx tranny is good for cruising.
i could be wrong. but i think that's what it is. i remember seeing a chart somewhere that showed the different gear ratios and such. forgot where though. maybe someone else can help you out.
Guest
Posts: n/a
if your gonna boost would it be worth it to just keep the dx tranny if your gonna run a t3/t4, then go with an si tranny if you were to run just a t3.
um ok. Look at it this way your running a t3/t4 with an si tranny chances are your not gonna be in full boost very long before you have to shift. dx tranny you gonna have more time to reach full boost and more time to stay in full boost. Now if you running a t3 on an si then its gonna spools much faster and you will prolly be at full boost by 2.5-3 k . If you were running a t3 on a dx it would really suck to have that turbo spinning it *** off and start to loss power high end. what so dumb about that? the most retarted thing iv seen is trying to hook up a honda motor with no hope.
[Modified by TEAM GARAGE SHIFTDOWN, 1:59 AM 10/6/2002]
i wondered about doing the dx tranny...... it seems basically like the people htat switch out their random bseries trannies for the LS trannyfor its longer gearing..
wanna repeat that in english??? with a dx u have a higher top speed with the si u have a faster aceleration is that what u meant???
As far as Boosting with the DX Tranny.. I got 2 words for that.. **** NO, I have used the DX tranny all race season, with small turbos or big, it doesnt matter it just blows to much, the gearing is way to long. Plus it puts way to much of a load on the engine each time you shift. Not to mention the DX tranny has smaller main bearings and more prone to break.
Si or ZC tranny... for boost..
Jeff Frank
i dont think so,maybe the HF has smaller bearings but the DX is the same,only diff is that the Si has a 4.25 final and the DX has an 3.88 final.
Guest
Posts: n/a
does your same skewed theory apply to sc'd and nitro applications?
please know what your talking about before you post somehting as illogical as this. this kid wants to know the differences in transmitions. providing him w/ misinformation will only **** him over in the future. if you dont want to be flamed in the future please provide others with factual information.
[Modified by TorteX, 2:36 AM 10/6/2002]
somebody got owned ^
I'm sure you will be happy with an Si tranny, I would think you are looking for the faster acceleration then gas mileage.
do you know if have a big difference between the dx and si transmission.so if he have a difference do you know if i have more power or more speed.
So you're saying if I have my DX Final drive swapped out for an SI final drive I will have an SI transmission?
Tuner Eddy
20
Jan 28, 2007 02:47 PM
serious
14
Jul 17, 2002 03:31 AM
