konig rollers
Old Oct 4, 2011 | 06:29 PM
wstmsol's Avatar
Default konig rollers
i was wondering if the rivets can be removed ?
Old Oct 4, 2011 | 07:13 PM
toyomatt84's Avatar
Sanji
Default Re: konig rollers
They're just plastic that is glued/pressed in. If you can remove them without breaking them, then you may be able to re-install them.
Old Oct 4, 2011 | 07:21 PM
wstmsol's Avatar
what tool ? and could you replace them with other rivets? like these http://www.nlmotoring.com/product-p/kithd46004.htm possible to try ?
Old Oct 4, 2011 | 07:32 PM
jserman's Avatar
I wonder if you can drill them out then put actual bolts in like in that link... I like the rollers also
Old Oct 4, 2011 | 07:44 PM
wstmsol's Avatar
yeah thats what i want to do :D
Old Oct 4, 2011 | 07:45 PM
jserman's Avatar
do it and let me know how it turns out... Do you have rollers now???
Old Oct 4, 2011 | 07:51 PM
wstmsol's Avatar
im pretty sure ima order them soon, ill let you know!
Old Oct 5, 2011 | 04:28 AM
toyomatt84's Avatar
Sanji
To be honest, there's not a special tool that removes those carefully. You'll have to just be creative when removing them, if you want to keep them from being damaged.
Those bolts (not rivets) should work fine, if you're willing to drill through the wheel's face to mount them properly. I'd make sure to use the proper sized drill bit, though (which would require having the hardware kit on hand).
Old Oct 5, 2011 | 03:36 PM
wstmsol's Avatar
alright thanks for the help man !
Old Mar 21, 2013 | 05:27 PM
Crex167's Avatar
Are you 100% positive they are plastic?
did you figure anything out?
Old Mar 21, 2013 | 06:23 PM
toyomatt84's Avatar
Sanji
From what I've seen, they're almost always plastic. But, I haven't seen every one out there.
Old Jul 22, 2013 | 07:06 PM
Crex167's Avatar
Old Jul 30, 2013 | 12:24 PM
4doorpimpn's Avatar
Another place you can check for replacement rivets is www.prestigewheel.com. They tell you how to measure them properly and I think they average around .50-.75 cents each.
zerovandez
Aug 19, 2011 04:42 AM
BumbleeBeeCRX
Sep 9, 2010 01:23 PM
natesfresh
Feb 23, 2008 10:41 PM
chisaiCheesam
Honda Civic (2006 - 2015)
Jan 23, 2008 09:19 AM
