92 gsr ys1 transmission help
Old Oct 4, 2011 | 12:13 PM
teggy92gsr's Avatar
Default 92 gsr ys1 transmission help
i have a 92 integra gsr with orig. b17a1 and ys1 tranny went out and i need mainshaft i have called bout 30 different places and looked all over the net and cant find anything can someone please help i dont no what to do and its the only car i own..i need a mainshaft bad if someone would sell one opr tell me where to purchase i would very greatly appreciate it thank u in advance..
Old Oct 4, 2011 | 12:29 PM
bnetkillzone's Avatar
Default Re: 92 gsr ys1 transmission help
Head over to the honda marketplace: link up there ^
Go to the selling and try to find it there, if no one has what you're looking for then post a WTB (Also under honda marketplace).
Old Oct 4, 2011 | 12:48 PM
teggy92gsr's Avatar
thanx for info i tried to buy it new from hondaunlimited and a few other places and was told discoutinued part. now i finally own my dream car but cant drive it i looked for it for 10 years now im in a hole with it.i already have alot of new tranny parts just need the mainshafti thought bout another trans but price ranged from 600 to 1200 for gsr i already have almost that in new parts but thanx
Old Oct 4, 2011 | 01:13 PM
teggy92gsr's Avatar
i would appreciate if anyone still might no where to purchase this
Old Oct 4, 2011 | 09:34 PM
Post up a want to buy thread for it if no one has it. Over in the hondamarketplace.
Old Oct 4, 2011 | 09:51 PM
h1ghsp3ed's Avatar
U can try the junkyard if ur lucky or if worse comes to worse just go to Acura
Old Oct 4, 2011 | 10:08 PM
teggy92gsr's Avatar
acura dealership says it is a discontinued part they cant get it and unable to find 1 at a junkyard all i can find is ls and i cant use that
Old Oct 6, 2011 | 07:09 AM
kimsuprapa's Avatar
Did you try majestic honda? You should at least be able to get the part # there and search google. Probably you best bet.
http://www.hondaautomotiveparts.com/
Old Oct 6, 2011 | 01:16 PM
teggy92gsr's Avatar
nothing that way either it just brings up dealer sites and ever dealer i called said the same thing discontinued and cant get it.
Old Oct 6, 2011 | 08:13 PM
Hidenplanvew's Avatar
You might be able to run an ls main shaft, I belave the Ls final drive drive gear on the main shaft is the same size. If it is the same and has the same amount of teeth you should be good to go. Just make sure you get a new Input shaft bearing while your there.
By main do you mean the input shaft?
Old Oct 6, 2011 | 09:20 PM
teggy92gsr's Avatar
bearin is done thats part y i dont wont to buy another trans i already have new synchros 2gear set assy new needle bearing well to put it basic just bout everything is new except main and countershaft. yes main shaft. i was told to try either b16 or b18 main shaft but i would like to no for for i noticed that 1st and 2nd gear r the exact same on mine and another model but im unsure of exactly which 1 that it is sorry to ramble on but ivee been fighting with this problem know for a few months im having trouble getting an strait out answer
Old Oct 7, 2011 | 05:53 AM
fcm's Avatar
fcm
Old Fart
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Where are you located?94
Old Oct 7, 2011 | 08:13 AM
teggy92gsr's Avatar
if u where askin me im n the US. virginia
Old Oct 7, 2011 | 10:56 AM
Mindgamez's Avatar
I got a Main Shaft. PM ME
Old Oct 7, 2011 | 10:59 AM
Mindgamez's Avatar
Ohh and the mainshafts between the LS and GSR are the same, its what goes on them thats diffrent, the only thing that has to be the same is the countershaft with the diff.
Old Oct 7, 2011 | 04:14 PM
fcm's Avatar
fcm
Old Fart
Hmmm, part numbers are differant... 92 GS-R KL5MT http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
92 LS KL5MT
Makes me think they are diff. 94
Old Oct 7, 2011 | 07:23 PM
teggy92gsr's Avatar
i know i cant use a 92 or 93 ls cause 1st 2nd and reverse r milled onto the shaft i was wondern bout a newer or later year. 92, 93, gsr.ls gear ratio is different
Old Oct 12, 2011 | 10:51 AM
Mindgamez's Avatar
92 LS KL5MT
Ive Mixmatched them before and everything worked fine. They all look exzactally the same, the only diff is the Syncros and the Hub for 3rd and 4th gear, The GSR have a stronger/Larger hub while the LS is smaller and not as beefed up. As for them being milled on the shaft, The only ones that are milled on the shaft are B16 S1 Trannys from a 90-91 Teg. Which are small spline shafts. Which would mean you do not have a GSR Trans.
ChrisStone24
Northwest (Sales)
Jan 10, 2010 01:45 PM
WildKardde
Mar 22, 2008 08:23 AM
slowassgsxr750
Jan 8, 2008 07:50 PM
FiNaFLaW
May 10, 2002 04:01 PM
89HF
Jan 12, 2002 06:50 AM
