GSR ECU...auto trans?
I have a automatic car and want to drop a gsr head on to make a ls/vtec, i found a gsr ecu, will that work with the auto trans? helpme out...
or try to get a JDM AUTO GSR ECU (Japan had auto GSR, right? correct me if i am wrong.. but i remember i have seen it.) then you should be fine..
Good luck
no i dont think that it would work with the auto. since how would the ecu tell the trans to shift? but i dont know much about that topic. so take my .02 as that.
unless he can find a AUTO GSR ECU from JP.
sure it is... i met someone online who had that setup. was running low 14's with 50 shot of nitrous.
there is no way if he is running a 5 speed GSR ecu.. auto tranny won't shift, period.
by he is using LS auto ECu then the LS/VTEC motor will only run like a nonVtec, it will never hit Vtec. eg. GSR can run with LS 5 speed ecu no problem buth it will lose HP and run like a LS simply coz LS ECU doesn't read to hit Vtec function.
but then again, 5 speed LS won't be able to use GSR ecu, i don't know the correct answer though but i know it won't work.
[Modified by PaChiLa Leader, 7:42 PM 10/5/2002]
i know Auto ECU would work fine with 5speed car, but i never try 5speed ECU on an auto. you sure man?
[Modified by PaChiLa Leader, 1:48 AM 10/6/2002]
[Modified by PaChiLa Leader, 1:49 AM 10/6/2002]
i know Auto ECU would work fine with 5speed car but i never tried it, auto ECU on a 5 speed. you sure man?
sorry man.. i was referring 5 speed ECU in an auto teg~~
i don't think it would work..
See the other HT member above.. stated "Experiment by putting a 5 speed LS ecu into someone's A/T ls. I bet it would shift. "
what do you think..
By the way, YEah i did auto to manual conversion too .. still have my OBD2B auto ECU in the car..and also running OBD1 ECU sometimes..
the only thing bothers me with my auto ECU is that check engine light comes on all the time and my D gage flashs every sec. lol.
what do you think..
the 5 speed ecu won't work on a auto teg... for auto teg ls/vtec setups, your gonna need a rpm activator to engage the vtec. MSD sells these. Or a aftermarket vtec controller like fields
__________________________________________________ _______________
This guy is right. To make this setup work your going to need a Vtec Controller.
When you get the GSR head your going to have to get a new intake because the manifold on the GSR sits lower than the LS. I also recommend getting new gaskets for the head and block when you make the conversion. You don't have to change your Ecu to get this to work. The downside to this is that the LS auto tranny is only going to be able to take 7000 rpm's which means your not going to get that powerful GSR redline of 8000. Now if your not going to convert from auto to manual then it makes no sense to get a GSR ecu because your tranny will never come close to hitting 8000 rpm's. You won't even reach past 7100.
so your saying i could keep my stock auto, non-vtec ecu and just buy a vtec controller and that will work? Also i have a header on my ls head, r the portd the same where i could just get the header ported to the new head?
http://www.modacar.com/products/Acura/Integra/MODAECT/
