remove rear view mirror ek coupe!?
Old Oct 3, 2011 | 11:43 PM
taylorgang's Avatar
Default remove rear view mirror ek coupe!?
having trouble removing the rear view mirror on my 2000 civic coupe (ek).
can anybody tell me how to properly remove it without damaging it?
trying to put a wink mirror on that's why.
and if anybody has any pics or advice on installing a
wink mirror on a 2000 civic ek coupe would also be very helpful.
thanks!
Old Oct 3, 2011 | 11:47 PM
xjoewhitex's Avatar
Default Re: remove rear view mirror ek coupe!?
It's only a glue/adhesive that holds it on, possibly run a razor blade in behind it and see if you are able to cut it off. But besure not to slice your hand open.
Old Oct 3, 2011 | 11:51 PM
Jdmglenn's Avatar
wrong, you gotta pull off that grey plastic cover, prying down on the long sides, then you will see the 3 phillips screws holding it to the roof
Old Oct 3, 2011 | 11:57 PM
xjoewhitex's Avatar
Crap I was thinking of how EGs are set up, totally forgot these are mounted to the ceiling. Good save.
Old Oct 3, 2011 | 11:58 PM
taylorgang's Avatar
is it possible if i could just take off the rear view mirror itself instead of having to take off the part that's mounted on to the ceiling, or its all one piece?
Old Oct 4, 2011 | 05:50 AM
deving916's Avatar
You remove these screws then you can put the plastic cover back up. 3 Screws hold the mirror to the roof, so remove them, then take down the mirror, and put the cover back on.
Very simple.
The mirror up to the roof is one piece.
Old Oct 5, 2011 | 12:29 AM
taylorgang's Avatar
Very simple.
just got it done, wayy easier than i thought!
thanks for the help peoples!
cticknor666
Apr 19, 2010 04:12 PM
Twisted Image
Jun 19, 2009 05:52 AM
iwanttogofast
Mar 24, 2008 03:20 PM
