To those of you who have a J's Racing Intake...
Old Oct 5, 2002 | 10:17 AM
Chris N's Avatar
Default To those of you who have a J's Racing Intake...
This should be a very easy install, but given what came in my package, I'm not entirely sure about all this. It seems that the rubber hose to connect the intake piping and the TB is not a 'normal' connector. One side is smaller in diameter than the other. I'm assuming that the smaller diameter side goes inside the intake piping. That way the larger diameter side would go over the TB and could be clamped down like any other intake.
My question is this: Does the intake just 'float' there with the rubber hose sitting inside the intake piping? I don't think the rubber hose get stretched over the piping, it's just too small for that. From the pictures on here, it is hard to tell what you guys did, or what the correct way is. Any help would be appreciated.
[Modified by 1107, 1:17 PM 10/5/2002]
Old Oct 5, 2002 | 10:21 AM
Flux's Avatar
Default Re: To those of you who have a J's Racing Intake... (1107)
I just sent you an IM, but to answer your question here: The rubber connector goes over the intake arm and over the throttle body...
You need to flip the rubber copnnector over and put the bigger end over the intake and the other end over the the throttle body...
Old Oct 5, 2002 | 10:25 AM
Shark Tank's Avatar
Default Re: To those of you who have a J's Racing Intake... (Flux)
flux is right, you have to work the connector of the intake, it will take a little bit of stretching and pulling but it goes right on
Old Oct 5, 2002 | 10:49 AM
Chris N's Avatar
Default Re: To those of you who have a J's Racing Intake... (CART fan)
Thanks Flux and CART fan.
One other question. The metal clamp goes over the TB? That leaves the intake only connected by the rubber connector... giving it a little flex. Yes?
Old Oct 5, 2002 | 04:15 PM
Shark Tank's Avatar
yeah, but i went and got another clamp and clamped the intake end down as well. dont over tighten it though
Old Oct 6, 2002 | 12:12 AM
B2FiNiTY's Avatar
So where do you mount the mounting bracket?
Old Oct 6, 2002 | 08:20 AM
Flux's Avatar
Default Re: To those of you who have a J's Racing Intake... (ExOdy)
Mounting bracket? I didn't get a mounting bracket.....
Old Oct 6, 2002 | 09:15 AM
Chris N's Avatar
There's no bracket. It doesn't need one once it is tightened onto the TB. Works great, I was just a bit confused with the rubber connector....
Old Oct 6, 2002 | 09:28 AM
B2FiNiTY's Avatar
Hmm.interesting.
Old Oct 6, 2002 | 11:05 AM
Shark Tank's Avatar
Default Re: To those of you who have a J's Racing Intake... (C5_ALLMOTOR)
mine doesnt bang and there is no mounting bracket. the filter is ALOT heavier than the actual intake
Old Oct 6, 2002 | 11:18 AM
Michael Delaney's Avatar
if it bangs around and scratches and falls apart are you going to let us know in the future or are you going to let that go unposted and only leave up the hype good news?
Old Oct 6, 2002 | 11:37 AM
Shark Tank's Avatar
Default Re: To those of you who have a J's Racing Intake... (Michael Delaney)
sure why not, dont expect that though, the car isnt even daily driven and if you look at the setup and cant really move around that much. i mean its in between the engine and the side of the car and the tower bar is on top of it. if you guys are so worried about it fab a brace or clamp yourself. it shouldnt be a big deal. how you car delaney, you figure out what you are going to do yet?
Old Oct 6, 2002 | 11:55 AM
Flux's Avatar
Don't be cynical...
Old Oct 6, 2002 | 12:56 PM
Tommy_Gunns's Avatar
If there is no mounting bracket, it just sits on top of the a/c lines? I'd made a mounting bracket if I owned one. Over time, sitting on the a/c lines is going to wear a hole into the CF intake tube.
Old Oct 6, 2002 | 01:04 PM
zer0zer0 TypeR's Avatar
Default Re: To those of you who have a J's Racing Intake... (Tommy_Gunns)
no mounting bracket, it just "floats" over the ac line. dennis you don't have to worry about it rubbing the ac line.
Old Oct 6, 2002 | 01:26 PM
Shark Tank's Avatar
Default Re: To those of you who have a J's Racing Intake... ('00TypeR)
well since i have no a/c at all that wont be a problem will it
Old Oct 6, 2002 | 01:29 PM
B2FiNiTY's Avatar
Lucky you. Looks like I'll just add the mounting bracket to my JDM collection.
Old Oct 7, 2002 | 01:20 PM
Chris N's Avatar
If it rubs and breaks, I'll post that too. Along with the hype.
You want bad news? I didn't get any instructions with mine. Not that I needed instructions (except for the rubber connector!!!), but the a/c lines needed to be moved for the intake to fit correctly and not hit a) the hood or b) the strut bar and it would have been nice to know that ahead of time.
Old Oct 22, 2002 | 05:17 PM
ALLMOTOR18's Avatar
where did you guys get the J's racing intake and for how much?
TIA
Old Oct 22, 2002 | 05:18 PM
B2FiNiTY's Avatar
Default Re: To those of you who have a J's Racing Intake... (GSRTypeR)
Check my sig.
Around $250-260.
Old Oct 22, 2002 | 05:49 PM
Mike M's Avatar
Founding Member
TIA
Still on Special $250 shipped
Old Oct 22, 2002 | 05:51 PM
(__________)'s Avatar
yep 250 shipped right here from one of the dealers in exody's sig
my_gsr_teg
Apr 25, 2010 10:12 AM
egcrew02
Jan 23, 2009 10:39 AM
itr1244
Jul 28, 2003 04:27 PM
jonnybravo
May 5, 2003 08:51 PM
Accord15
Apr 18, 2002 06:04 AM
