FS clean, built, & boosted 95 teg CBUS Ohio
Old Oct 3, 2011 | 02:15 PM
x still jaded x's Avatar
Default FS clean, built, & boosted 95 teg CBUS Ohio
looking to sell 95 integra 123k on body. with full turbo kit. asking 8000 OBO dont need a fast car anymore. trying to avoid speeding tickets. have documentation and receipts and dyno sheets. GSR Black leather interior GSR Gauges w/ 8200 rev limit Custom gauge bezel (holds two gauges) Oil PSI autometer Ultralight gauge (+ electrical sending unit) Boost autometer Ultralight gauge Apexi Turbo timer Custom Billet "Turbo" foot pedals Alpine Head Unit Infinity 6in door speakers (front) MTX 6in door speakers (Rear) Complete monster wiring (RCA, Remote) Viper alarm Exterior: S2000 antenna Type R Spoiler w/ LED 17in Polished Wheels w/ tuner lugs 01 GSR all red tail lights Clear front bumper lights Deadbolt (engine disable) hood lock Engine / Performance B18a1 .20 over balanced/blueprinted block ACL Complete Bearing set GE Block guard JE Pistons Eagle rods /ARP rod bolts JE rings ARP Studs STR Polished cam seal All new seals/belt, Sensors, Water/Oil pumps Balanced/ Micro-polished Crank Fully ported B18b1 Head (Port matched intake to JG runners, exhaust to manifold runners) 3 Angle valve job Crower SS oversized valves Crower titanium retainers Crower dual valve springs B18b Polished cams JG Edelbrock Victor X Intake manifold Carbing oil catch can AEM Fuel rail AEM Fuel filter AEM Fuel pressure regulator Dual tapped B18b Oil pan (-10an) SS Oil feed line/relocation line & fittings Stainless Braided Fuel line Walbro 255 lph High flow fuel pump 780cc Precision injectors AEM EMS AEM Uego Custom mounting plate Garrett/Air research 60-1 78 trim turbo (.48ar/.70ar) 2.5 stainless Intercooler piping / hose couplers HKS SSQV Blow off valve Tial Silver Waste gate Stainless Turbo manifold Stainless 3" Down pipe Thermal Research & Developement 3" Stainless Turbo Catback Custom Air filter Custom AC Lines w/ Thermal sleeving Custom stainless braided oil return line w/ Thermal sleeving MSD 6al Ignition MSD Digital Blaster coil Custom Ignition mounting plate/bracket MSD Distributor external cap and wire MSD Plug wires 8.5mm Fluidyne oversized dual core aluminum radiator Custom coolant overflow can Custom Radiator mounting brackets RPS 470 ft lbs torque clutch/pressure plate OEM Throw-out bearing GM Synchromesh Trans Fluid NGK Plugs 7* colder Oil filter relocation kit (Custom stainless braided setup) polished oil cooler High PSI -10an Oil lines and anodized fittings RevHard Stage III Intercooler (32x9x3) Nuespeed Short Shifter Prothane Shift bushings Suspension: KYB AGX 4 way adjustable struts Eibach Proline lowering springs Nuespeed Rear lower Strut bar L-Con Traction Bar Polished upper strut brace Energy suspension motor mount inserts Brakes: SS brake lines Wilwood Big brake kit (4 piston calipers/ Oversized rotors) New OEM Honda 1" master cylinder
Old Oct 3, 2011 | 02:35 PM
Fibercation's Avatar
Default Re: FS clean, built, & boosted 95 teg CBUS Ohio
Post hurts my eyes lol....... reformat and add some pics
Good seller bought car from before!
Old Oct 3, 2011 | 02:52 PM
maxwellmercer's Avatar
This. Spacebar bro.
Old Oct 3, 2011 | 07:49 PM
Ryan97's Avatar
ill give you second place for best try.
Old Oct 4, 2011 | 01:04 PM
B Dap's Avatar
oofta, I know everyone said it but please re-type that. I got about 3 words in and stopped.
Old Oct 4, 2011 | 01:20 PM
frogg5872's Avatar
Apexi Turbo timer
Alpine Head Unit
Viper alarm
GE Block guard
JE Pistons
JE rings
ARP Studs
B18b Polished cams
AEM Fuel rail
AEM Fuel filter
AEM EMS
Custom Air filter
MSD 6al Ignition
NGK Plugs 7* colder
Suspension:
L-Con Traction Bar
Brakes:
SS brake lines
I think that helps
Old Oct 4, 2011 | 01:26 PM
frogg5872's Avatar
now some pics and numbers would be awesome
x still jaded x
Oct 11, 2011 07:45 AM
WhoNeedsVtec
Oct 18, 2007 12:01 PM
awdgsx96
Feb 20, 2007 08:23 AM
