F/S: H22/5th Gen Prelude Parts
Old Oct 3, 2011 | 01:29 PM
sfljdmbb6's Avatar
Default F/S: H22/5th Gen Prelude Parts
I started my 5th gen about a year or so ago and I just dont have as much time as I used to. I will slowly start parting out the car and any spare parts I may have laying around. My loss is your gain. All prices are OBO. I will add to the list as I start selling parts little by little. Thanks for looking!!!
I am located in Miami, FL. Send me a text to 305-803-3293 or a PM if you are interested in anything.
http://s135.photobucket.com/albums/q...jdmbb6%20parts
http://www.preludeonline.com/f82/sfl...6-build-260789
5th gen Mugen replica sideskirts. mint never installed or painted. $130 plus shipping
OEM radiator and fans. $80 plus shipping
5th gen aftermarket front bumper. unpainted. $100 plus shipping
4th gen digital climate control unit. will come with pigtail. $60 plus shipping
5th gen manual clutch lines, fittings and bolts. all but 2 lines are new from the dealer asking $180 plus shipping
OBX throttle body spacer BNIB never used $40 plus shipping
Automatic starter working last time tested $50 plus shipping
OEM cams and gears $70 plus shipping
H22 Gates racing thermostat. $10 plus shipping
5 lug J-Mags light curb rash. barely seen. no tires. $400 plus shipping.
P5P nippon type-s pistons BNIB never used come balanced, with wrist pins, locks, and rings already gaped $175 plus shipping
OEM pistons and rods from H22A4. No rings will include new rod bearings. $80 plus shipping
Auto half-shaft $20 plus shipping
OEM fuel rail $20 plus shipping
h22 injectors OBD-1 with clips and resistor box $60 plus shipping
bumper side lights clear $15 plus shipping
oem turn signals (cracks in glass) $15 plus shipping
oem taillights (cracks in glass) $60 plus shipping
a/c compressor $50 plus shipping
2 power steering pumps $25 each plus shipping
OEM fog light kit with yellow capsule mod $200 plus shipping
"PRELUDE" honeycomb grill $100 plus shipping
"PRELUDE" JDM trunk mat. $85 plus shipping
I am looking to see if there is any interest in my motor, transmission and shell.
Here is a small rundown of motor and transmission:
Darton sleeved H22A4 block
Eagle "H" beam rods
CP 11.5:1 high compression pistons with upgraded pins
Entire rotating assembly has been balanced including flywheel and crank pulley!
Kaizenspeed balance shaft delete
BNIB OEM oil pump, water pump, and all gaskets
Mishimoto radiator, shroud, fans upper radiator necks has been modified for -16 lines can have lower modified to match.
ARP head and main studs
Race port and polished head
SMSP replica header
Skunk2 flat valves, springs, retainers
Supertech valve guides
Skunk2 pro2 cams with titanium gears
Skunk2 intake manifold with 70mm throttle body drilled and tapped for direct port nitrous
Hondata intake manifold gasket
ID1000 injectors
Hondata s300
DSS 3.9 axles
Syncrotech carbon syncro set
Fidanza flywheel (not the lightest version)
Currently makes 255 to the wheels on E85
I would like to have everything sold by the end of October or early November
Old Oct 5, 2011 | 08:18 PM
sfljdmbb6's Avatar
Default Re: F/S: H22/5th Gen Prelude Parts
bump
Old Oct 7, 2011 | 05:57 AM
sfljdmbb6's Avatar
bump
Old Oct 7, 2011 | 06:51 AM
97CBMbb6's Avatar
bump for a local. might hit you up for some things. glws
Old Oct 8, 2011 | 01:05 AM
99preludeowner's Avatar
how much for the power steering pump? shipped to 90745? any pictures? how is the condition?
Old Oct 11, 2011 | 04:19 AM
AznBlueBoy's Avatar
part out those ID1000?
Old Jan 4, 2012 | 12:05 PM
momolead's Avatar
how much for dril and trunk mat together, plus wood type lining to hold up the trunk mat?
Old Feb 20, 2012 | 03:25 PM
crosser11's Avatar
bump for a sick bbuilt motor
Old Feb 24, 2012 | 09:59 AM
msalhei's Avatar
you willing to part the head/motor?
Old Feb 28, 2012 | 02:35 PM
rokkerHM's Avatar
just wondering if you still have the headers in your pics from the link, lmk if you do and want to sell them. thanks.
51ludeguy
Jan 30, 2012 08:12 AM
51ludeguy
Jun 16, 2008 09:49 AM
51ludeguy
May 19, 2008 08:00 PM
