Ep3 Center Console Removal
I'm guessing those are the bolts underneath the rubber mat in the console?
Push the cupholder out of the way, then use a piece of tape, stick it to the bottom of the console and pull up. This may take a couple tries.
This will let you remove the rubber padding (Part "E" in the diagram) on the bottom revealing the bolts. Then you can use an extension to remove the bolts.
deeice30
Oct 15, 2003 01:43 PM
Sean EH2
Jul 31, 2003 11:50 AM
