Won't start unless gas is held down.
Old Oct 3, 2011 | 10:48 AM
sc34dc4's Avatar
Default Won't start unless gas is held down.
I'm not sure if this belongs here or not. Might be for the tech/misc section.
Yesterday I went to start my car to move it and after a few seconds it just shut off. It won't start back up unless you hold the gas in. Then it runs rough as hell and sounds like a Subaru. I had some spare distributor stuff laying around so I changed it out just to see and nothing. Coil-cap-rotor
I put new plugs in it and pulled them after I got it to start. They are black as coal and wet from gas. I was tuned in June so I'm not sure if that may have something to do with this or not. It was done at IMW by John Kerr and I know he's good at what he does so I wouldn't think that's the cause but who knows.
Any suggestions?
Old Oct 3, 2011 | 11:59 AM
88_hatch_ls's Avatar
Default Re: Won't start unless gas is held down.
i kinda have the same situation with my car in a way, i had the vavles adjusted and it helped a little.. new dizzy, injectors and nothing the head when i got it had 4 bent valves and replaced them with used ones i bought on ebay and i lapped them in and seemed to seat correctly but when i did a compression check later on that cylinder had low compression so i either have bent valves or they are not seated properly and that makes my car run like that to where i give it gas to start it and it will run like a suby for a sec or two then straiten out.. so idk maybe a valve adjustment for you or do a comp test?
Old Oct 3, 2011 | 12:41 PM
slotec's Avatar
my car does the same thing. I have to hold the gas to get it to start then itll idle fine
Old Oct 3, 2011 | 12:44 PM
carnot's Avatar
Check electrical connections and grounds. What did you use for tuning; can you datalog?
Old Oct 3, 2011 | 01:22 PM
sc34dc4's Avatar
Turned out it jumped time sitting in my driveway. I got it to start and idle again on it's own power. Revs up kinds rough so I believe it's still maybe 1 tooth out. At least I know where to start again when I get back to it. I was doing this in the driveway and it's raining plus 45 degrees so I called it quits for the day.
Old Oct 3, 2011 | 04:26 PM
Gunmetal_B20_Hatch's Avatar
was gonna say MAP sensor...
jordy478
Aug 9, 2012 05:56 AM
sc34dc4
Oct 3, 2011 01:20 PM
vartok
Jul 22, 2011 07:18 PM
svacca1
Jan 2, 2008 03:24 PM
Tr0LL
Nov 5, 2006 12:20 PM
