Need a little wiring info for zc or teg dizzy
Im wiring a zc swap for a freind but the motor came with no dizzy so the two wires that are coming from the exhaust came side where cut. Dose anyone know where these two wires go and if you canuse i si dizzy or dose it have to be a teg or zc dizzy? thanks
going to have to be a ZC or 88-89 teg dist. i prefer the 88-89 teg as they are a bit more reliable than the ZC. as far as that sesor with the cut wores that is for the exhaust came sensor (cyp sensor). those need to be added at the Ecu. there is a few sites out there that have the info on this. check www.hasport.com look for the Dx to ZC wiring conversion. also check here http://hybrid2.honda-perf.org/tech/4gdxtozc.html this is one of the better wite ups, it what i used when i did my ZC swap
