Reassemble D16 Bottom end w/motor in car?
Old Oct 3, 2011 | 06:48 AM
SlowPokeEg's Avatar
Mike Jones
Default Reassemble D16 Bottom end w/motor in car?
Had some catastrophic failures and my pistons cracked on the ringlands.
We were able to remove the rods and pistons with the motor in the car and the girdle attached.
It was tight, but we were able to do it. Reassembly concerns me though.
Anyone ever do this?
Any pointers for putting new rings,pistons,bearings in there?
Old Oct 3, 2011 | 09:07 AM
hondamark35's Avatar
Default Re: Reassemble D16 Bottom end w/motor in car?
as i've recently learned, it's far cheaper to pick up a used short block than rebuild. it's also much easier to swap in a short block than properly build one back up. (esp. with a lack of experience and tools)
that's my recommendation. but it's your car so do what you like.
Old Oct 3, 2011 | 10:34 AM
SlowPokeEg's Avatar
Mike Jones
My car has 75.5mm Vitaras with FJ rods.
Car was assembled by local engine shop. Crank was at 1:00 when head was TDC. Needless to say, my pistons cracked
So the motor only has 300 miles on the build.
Purchased new bearings, pistons, and rings. Now I need to put the new ones in....somehow.
Old Oct 4, 2011 | 06:03 AM
SlowPokeEg's Avatar
Mike Jones
This forum isn't what it used to be! lol
Old Oct 4, 2011 | 08:04 AM
strategy400's Avatar
For the amount of hassle of working under the car you could just pull the engine and put it on a stand. For about $250 you can buy a new hoist and stand.
Old Oct 4, 2011 | 08:42 AM
fallrivercolin's Avatar
Im with you. Spend a few hours pulling the motor and do it right.
h2b_sedan
Sep 30, 2009 11:38 AM
panda ej1
Apr 25, 2009 03:13 PM
drowzysleeper
May 26, 2005 11:38 AM
Black R
Oct 16, 2001 04:53 PM
mike2016
Jul 5, 2001 11:41 PM
