gsr a/c setup
I have a gsr swap in my eg and I was informed that to keep the stock civic a/c setup all I would need is a 99/00 si bracket. I bought one and the compressor doesn't line up. Is it not an si part or are the gsr mounts different or what? Any help would be awesome.
You can not use an Si bracket, it is made to fit a B series compressor.
You are looking for one of two brackets that fit a d series compressor to a B series engine like a B18C
- dohc vtec honda del sol
- any 97-01 honda crv
OP, after you bolt on the compressor, you'll be able to attach the A/C lines together without any confusion.
Also, I hope you still have your bolts because they are like 10 bucks each from dealer.
saemoonyang
Oct 14, 2010 11:08 AM
JDMCRX
Jun 18, 2009 05:11 PM
phanatic
10
Aug 1, 2006 02:35 PM
