Smoking B16a2
Old Oct 2, 2011 | 01:47 PM
Sagara09's Avatar
10 Year Member
Default Smoking B16a2
I have recently noticed my B16a2 burning a bit of oil. The smoke is a blue and white color and gets bad at high RPM's. I did a compression test and was 180psi in all for cylinders. I know it is not bad but not the best. I then removed the spark plugs and number 1 and 2 had oil on them with 1 being the worst. I replaced the valve cover gasket and the gaskets that fit around the spark plug hole. I then started the car up and it was smoking still. I figured it would go away due to burning off the excess oil that was possibly left. However, it did not.
I took it around the block and hit VTEC a couple of times in first and noticed the blue smoke. Once I parked and shut off the car I took out plug 1. Blue smoke was coming out of the plug inlet. I checked number 4 and nothing.
The engine, all together runs smooth. No hic-ups besides the idle issue. I am guessing either the valve stem seals or possibly the oil control rings. I am new to the Honda game so I am unsure if I should be highly concerned.
Questions:
Is this a major concern?
How likely is it something in the bottom end?
What are the likely possibilities?
Notes: Thank you for any help and information ahead of time.
Old Oct 2, 2011 | 01:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Smoking B16a2
Leakdown test.
Old Oct 2, 2011 | 02:00 PM
Sagara09's Avatar
10 Year Member
Originally Posted by grumblemarc
Leakdown test.
Would that only determine the valve seals?
Old Oct 2, 2011 | 02:05 PM
The Grumpiest
https://honda-tech.com/forums/acura-integra-6/%2A%2A-how-leakdown-test-%2A%2A-1491041/
Old Oct 2, 2011 | 02:11 PM
Sagara09's Avatar
10 Year Member
Thanks for the info.
Red-Rag-B18
May 4, 2010 07:04 PM
anjapower
Jun 3, 2009 09:02 PM
patrick4588
Aug 23, 2007 09:47 AM
jaymes2030
Jan 19, 2004 07:14 PM
Nos4R2
Mar 29, 2002 12:55 PM
