FS: Oct-Dec Race PARTS ONLY
Only post for sale ad's of RACE PARTS
NO WTB
DO NOT REPLY TO A POST.....PM the person....Keep this thread free of banter....just FOR SALE Posts
Must have:
Contact
Location
Price
Chad
NO WTB
Must have:
Contact
Location
Price
Chad
Contact: PM me!
Selling GSR Calipers with used 10.3" Rotor's. Calipers work flawlessly, no binding, no uneven pad wear.
I'm also selling them with an extra pair of brand new rotors ($80 Value) and Hawk HP Plus brake pads with around 40% life left.
Asking $150 obo picked up in So Cal
Contact: PM me!
Contact: PM here
Prices don't include shipping.USPS and Fedex are what I generally use.Paypal accepted.My prices are my current low point-no lowballs please.
I have for sale several items I no longer need after piecing together a new suspension setup for my E36 M3.
-Tein 2.5" diameter,7" tall ,9k/504lb coilover springs. Part number Q090-GECI.These are the front springs out of a Tein E36 coilover kit.Will work in any 2.5" inside diameter coilover application.
$65 for the pair
-2.5" ID,7" tall coilover springs.In excellent condition.475 lb rates...Put on tester this morning,and they tested 471,475,478 and 479lbs,respectively.
$40/pair
Contact: PM here
$65 for the pair
$40/pair
I was going back and forth on this project, and just decided I had way too many other things to do. Complete setup, pump had built in relay, so all you need is the fuse or circuit breaker of your choice and a cheap switch if you want to turn it on and off.
$350 plus shipping and payment fees. Located in SE Louisiana
PM me here.
PM me here.
Pics will be up tomorrow evening, I have two Long harnesses with the additional crotch straps.
One expires at the end of 2011, and the other expired in 2008, both are perfectly good for hard parking, HPDE's or depending on your region and series RACING.
Price ($500) is for the PAIR.
buyer is responsible for shipping and paypal but its small enough to fit in those USPS boxes so it shouldnt be more than 7 bux.
-Mark
-Mark
Contact: PM or call/text 914 474 9731
Selling this used Fluidyne High Performance DB-30416 oil cooler. It was taken out of an RX7 race car to switch over to a larger unit for use with a V mount setup. Nothing wrong with it, no leaks, no debris. All the fins are in good shape - the only thing is that it has a bit of overspray on it but that will rub right off with some scotch brite.
Specs:
6 1/4 in. x 14 3/4 in. x 2 3/4 in
-8an bungs
Retail for around $300 new, asking for 180 shipped.
http://www.summitracing.com/parts/FLD-DB-30416/
Specs:
-8an bungs
Recaro SPG. Overall it is in good shape. There is some wear on the bolsters, small hole on left bolster, several small holes on the middle pad, and some scrapes from the rails. Also it could use a good cleaning.
This seat belonged to Ryan (coolhandluke), Mark (heeltouge), and now myself. I pass it on for someone else to properly use it. It has a birth date of 4/2007.
$650 shipped/Paypal'd (gift)
All parts are located in Irvine/Anaheim area. I will ship at buyers expense.
All parts are CASH ONLY. NO TRADES.
Comptech 22mm Sway Bar and Subframe Brace for EG/DC - $300 OBO
Crow Enterprizes 6 Point Harness - $75 OBO
Magnaflow Turn Down Race Exhaust (exits under shifter) - $175 OBO
Greddy SMI Sweeping Oil Pressure/Temp Gauges with Control Box - $325 OBO
AEM ITR 3in CAI w/ K&N Dry flow 3in filter - $225 OBO
Recaro SPG Pro Racer - $900 OBO
JDM INTEGRA TYPE-R 98+ 4.785 FINAL DRIVE KIT B-SERIES
$410 shipped via UPS including paypal fees.
paypal funds & email address/contact: vtecjustin@gmail.com
used in great condition.
Integra Type-R LSD / B-series LSD
Used, good condition
$400 shipped including paypal fees.
comes bare with no ring gear & no differential bearings.
email for pics. vtecjustin@gmail.com
i have F7 lcas(itr app) and GC top hats for sale. both were on the track car for about 10 events with limited street miles.
Function7 LCAs- 250 Shipped.
GC Top Hats- 105 Shipped.
I have these SRR trunk latches. i have had them for a while ive wanted to use them but dont know if i will so im passing them along for someone to use properly. new in the box never used. 85 shipped and pp
Wilwood Dynalite 4 piston big brake KIT custom 11.8" setup. The rotors have been upgraded to the best rotor wilwood has that are 170 a piece, Also the pads have been upgrade to Carbotech xp12's 2 sets of pads that have 10-20% left of pad. Also the caliper bracket is not aluminum it is been made in steel to handle the heat and stress. These also have custom brake ducts that come with the high temp hose, hose stays, and the modified turn signals. These clear some 15" wheels with out a spacer like Team dynamics, some rotas, and most high end wheels such as volk, Almost all 16s clear no big deal. Don't be fooled about the fast brakes clearing all 15" wheels they don't clear 949 wheels with out grinding on the caliper or running a spacer.
PRICE DROP $600
P1 Splitter kit, Comes with lip, Splitter blade, and quick disconnect brackets. $450
PRICE DROP $600
olite 6R Brake calipers. Part numbers 12-1598 and 12-1599FS. These 6p piston calipers have a full set of Thermolock Pistons and stainless heat shielding. They are from a Winston Cup road course car and will fit many circle track and road race applications. They have some clearancing done to allow them to fit under a 15in steel wheel. That will not be necessary for bigger wheels
This sale includes a set of BRAND NEW Pads pre-burnished from Wilwood. Part Number is 15-5742 Bolt them on and race for ever. They are thick.
Also included a set of AP 12.625"/321mm by 1.25"/32mm rotors with aluminum hats CP2494-957. These are a floating rotor setup. One rotor is cracked but the other is good. They work perfectly with the calipers. The hats are drilled for 5x5 bolt pattern. There is a pair just didn't have room in the picture for the other.
Also included is a spare set of AP Racing hats (CP2494-1141) drilled for 5x5 bolt pattern and utilizing the 10x6.25 rotor pattern
Whole package $700. Will work on Trans AM and GTA cars perfectly. Also work on Corvettes Firebirds, Mustangs, etc. Would be great for a 25 Hour of Thunderhill car. You could probably do the whole event without a pad change. They won't fit my GT3 Car.
