1991 wagon
Old Oct 2, 2011 | 08:49 AM
turtle63's Avatar
Default 1991 wagon
s light for shifter stays on wont go into 3rd 4th need to know why ,,thx.
Old Oct 3, 2011 | 05:54 AM
oneprblmcat's Avatar
Default Re: 1991 wagon
With mine (also 91 wagon) it was a bad connection at one of the plugs to the transmission. I had pressure washed the engine bay in preparation to chase down some leaks. After washing I pulled all my connections apart, blew them out with air, and applied some dialectric grease before putting back together. I had not fully connected one of the shift solenoid connections I believe (memory is foggy) and once I found that it was all good. Other than that, hopefully you'll get better info from someone else here.
Old Oct 3, 2011 | 05:56 AM
Or was it the gear selector switch? Anyway, check all your connections first.
Old Oct 4, 2011 | 08:43 AM
Alright, now that you think I'm crazy, I have finally remembered which connector it was. It was for one of the magnetic pick-up sensors, either the main (front) or the (counter) rear on the far pass. side of the trans. I'm just not sure exactly which one. So I'm guessing you've got a bad pick-up sensor.
Good luck
Chris
Yovngroyal
Jun 27, 2019 07:32 PM
nghtshd88
Mar 30, 2016 11:18 AM
BlendedEM1
Apr 12, 2011 02:40 PM
DC5mike
Jun 27, 2008 06:16 PM
williamsergio
Sep 26, 2005 06:13 PM
