High powered DSM's Lets see em'!
Old Oct 1, 2011 | 02:13 PM
1KWHP1G's Avatar
Default High powered DSM's Lets see em'!
Lets see some pics or videos of your hi-powered Galant VR-4's,Eclipses,Lasers,or Talons. It can be barely a 10 sec car or a solid 8 sec car. If it requires slicks on all 4 to get traction it belongs in this thread.
I'll start out. Heres mine.
Old Oct 1, 2011 | 11:38 PM
dantamparacer's Avatar
Default Re: High powered DSM's Lets see em'!
I thought this was HONDA-tech.com, did i type in the wrong website
Old Oct 2, 2011 | 12:14 AM
Ricer no 7's Avatar
lol its all good dsm are sick too hella fast on the street with those awd launches
Anyways more info on your car plz thanks.
Old Oct 2, 2011 | 02:21 AM
1KWHP1G's Avatar
oops,think I meant to post in the "other makes" section. Oh well,it has forced induction.lol
Old Oct 2, 2011 | 02:46 AM
1KWHP1G's Avatar
Here ya' go.
Well,heres a quick rundown of what the has been done to it.
*Gunn Auto short block (Pauter rods,JE slugs w/larger Casidium coated pins
*Headway Performance cyl. head (o-ringed, race valve job,race port)
*Kiggly beehives
*Kiggly HLA pressure regulator
*Fel-Pro MLS Permatorque gasket
*A1 H-11 studs (1/2")
*Kelford 1-TX280 camshafts
*Greddy kevlar timing belt
*Fidanza cam gears
*Modified oil pump
*Garrett GT4202
*Shearer top mount manifold
*3.5" charge pipes (aluminum)
*5" core I/C
*Hogan intake manifold (2 pc. race plenum)
*Wilson 90mm billet TB
*Tial Q BOV
*Tial 44mm gate w/2.25" outlet
*4" Stainless side exit steel exhaust
*Shepherd tran dogbox (4 speed w/welded diff)
*DSS 3.5" HD driveshaft
*DSS level 5 axles
*Shep T-case
*Haltech E11v2
*J&S SAFEGAURD (Individual cylinder knock monitoring system)
*MSD DIS-4 High Output ignition
*Tubular stainless steel rad support
*10 pt. chroe moly cage by Tim @ Coast Chassis
*Simpson skyjacker chute
*Simpson window net
*Sparco race wheel
*TCi line lock
*CXRacing 3 row Honda style radiator
*Torque Solutions carrier bearing/driveshaft support CNC'd spacers
*Weldon 2345A pump
*PTE 1,600cc injectors x8
*Solid steel motor and trans mounts
*Solid steel rear diff mounts
I'm leaving out a lot of stuff. This was just off the top of my head. Car has gone 9.4's @ 151mph with a lot less power and more weight. We're estimating a full second drop in E.T's.
Old Oct 2, 2011 | 02:56 AM
1KWHP1G's Avatar
*-10AN lines from pump to rail
*-12AN to dual -10AN's to the tank
*MSD 2 post coils (x2)
*Aeromotive FPR
bowflex21
Oct 6, 2007 08:35 PM
VIS250P
Jan 2, 2007 02:31 AM
DaKINE-Ek
Oct 4, 2005 02:29 PM
bryant
Jan 8, 2004 06:51 AM
social_control
Jul 20, 2003 08:59 PM
