best way to adjust zeal's?
Old Oct 5, 2002 | 07:27 AM
jonas's Avatar
Default best way to adjust zeal's?
is it better to adjust the top one? or the bottom one?
i'd think the bottom one (the actual bottom half of the coil over) because it looks as if it would retain travel (sorry if that sounds dumb )
but if the coilovers are on the car, i wouldn't be able to adjust the bottom one because it would be secured by the damper fork.
Old Oct 5, 2002 | 08:03 AM
jonas's Avatar
Default Re: best way to adjust zeal's? (jonas)
TTT
Old Oct 5, 2002 | 08:13 AM
xtrafastcivic's Avatar
you can move the bottom one??? sorry never seen zeals
[Modified by XtraFastCRX, 9:16 AM 10/5/2002]
Old Oct 5, 2002 | 08:15 AM
jonas's Avatar
Default Re: best way to adjust zeal's? (XtraFastCRX)
yep
Old Oct 5, 2002 | 08:16 AM
carl_aka_carlos's Avatar
well, with the bottom adjustment you can lower/raise the car w/o affecting the pre-load on the shocks...meaning you could 'slam' your car and not worry about riding on the bumpstops...if that's what you're lookin' to do....nice coil-overs BTW
Old Oct 5, 2002 | 08:18 AM
jonas's Avatar
Default Re: best way to adjust zeal's? (carl_aka_carlos)
yeah, thats what i was thinking as well. but if i wanted to adjust the height from the bottom one (while the zeals are on the car).. i wouldnt be able to turn it because it would be secured by the fork
Old Oct 5, 2002 | 08:23 AM
i would say adjust both, adjust the shock length to a desire point, better make sure that both sides are the same then adjust the rest of the desired height with your springs..
Old Oct 5, 2002 | 08:25 AM
yoshi234's Avatar
I shoot brides
nice sus
according to zeal/endless, the CO's are packed at what they have detemined to be optimum setting (height wise).
since i bought mine used, here's what I did:
1) loosen the spring perch and then hand tightened the perch to make the spring sit snug
2) then adjusted the bottom to get the final ride height (3/4" lower in front, 1/2" lower in rear)
yshi's disclaimer:
not sure if this was the correct way to do this, but the above steps are what I did and seems to work
Old Oct 5, 2002 | 08:39 AM
jonas's Avatar
Default Re: best way to adjust zeal's? (yoshi234)
nice sus
doh, too late i already messed with them once they got out of the box lmao.
here's what I did:
I did #1
but #2 .. did you do that while it was ON the car? or did you just do trial and error
Old Oct 5, 2002 | 08:42 AM
yoshi234's Avatar
I shoot brides
j/k
I did #1
I just kinda eyeballed it and got lucky the 1st time
yshi - who recommends also reading his reply in the comp forum
Old Oct 6, 2002 | 05:27 PM
Anderson's Avatar
is that how you would go about adjusting BuddyClub racing spec dampers??
Old Oct 6, 2002 | 05:30 PM
disordeR's Avatar
do the zeals come with a manual or not?? i am guessing it's all in japanese...
Old Oct 6, 2002 | 05:36 PM
Tommy_Gunns's Avatar
Wow, what a great design, that would be able to accomadate all sort of springs if you choose to change them out (without the use of helper springs).
You sure would get your money's worth when you go to get your car corner balanced
Old Oct 6, 2002 | 06:54 PM
jonas's Avatar
Default Re: best way to adjust zeal's? (disordeR)
yeah.. the zeal's come with a manual..but its in japanese
anyways.. i got them on, and luckily for me.. i got the ride height right the first time like yshi did
Old Oct 6, 2002 | 07:20 PM
John McClane's Avatar
post sunshine slammed
Old Oct 6, 2002 | 07:30 PM
AllMotorITR's Avatar
New User
Default Re: best way to adjust zeal's? (tastykakes)
Yeah let's see pics of your ride height!
Old Oct 6, 2002 | 08:51 PM
jonas's Avatar
Default Re: best way to adjust zeal's? (AllMotorITR)
Old Oct 6, 2002 | 08:54 PM
yoshi234's Avatar
I shoot brides
hrm, doesn't seem low enough...go tighten the spring perches some more
Old Oct 6, 2002 | 08:57 PM
jonas's Avatar
LOL
it was already slammed ON JACKS
i have A LOT more left on the threads if i wanted to slam my car into China
edit: dirt on rotors. me =
[Modified by jonas, 9:58 PM 10/6/2002]
Old Oct 6, 2002 | 08:58 PM
Mario's Avatar
Do yourself a favor, and loosen the upper bolt on the fork.
Voila.
Old Oct 6, 2002 | 08:59 PM
jonas's Avatar
Default Re: best way to adjust zeal's? (Mario)
yeah, i know. but it's already done.. and got lucky getting it right the first time.
Old Oct 6, 2002 | 11:43 PM
tnd2gen's Avatar
This is why you purchased coilovers, so that you can adjust them to suit your needs. Try for yourself, youll be amazed at how informative a little experimenting can be....Also, it would help if you explained the purpose of your driving???gymkhana, circuit.... tire size (clearance). I have the same coils and I am constantly adjusting both to try to improve my times on different circuits.
Old Oct 6, 2002 | 11:50 PM
disordeR's Avatar
Default Re: best way to adjust zeal's? (tnd2gen)
you two gonna corner weight?
d-ramey
Acura TSX
Nov 5, 2014 06:58 PM
thebluecrx
Feb 7, 2011 02:38 PM
5Point7Liter
Suspension & Brakes
Dec 14, 2006 07:08 PM
94integrals
Jul 29, 2002 09:53 AM
