Cluster and dash lights
Old Oct 1, 2011 | 08:48 AM
ekjdm89's Avatar
Default Cluster and dash lights
I have a 94 honda accord the cluster lights and dash board lights are out checked out all the fuses, and I don't know if it might be a relay or jus maybe as simple as a few bulbs behind the cluster or behind da dash board. I need a little assistance.
Old Oct 2, 2011 | 06:10 AM
Lost Again's Avatar
Default Re: Cluster and dash lights
Could be the bulds, I'd check the dimmer first before pulling the cluster.
Old Oct 2, 2011 | 07:16 AM
TheMuffinMan's Avatar
He knows where you live!
You may think all the fuses are good.....I would suggest re-checking. The Small Lights Fuse is the main culprit - under the hood.
The other option *usually* is the dimmer switch to the left of the steering column. Just head to a junkyard and replace that guy.
sol-oto
Jun 17, 2018 08:56 AM
tutolo14
Sep 11, 2012 04:30 AM
Phils
Jul 27, 2007 11:58 AM
SlowazzGSR
Mar 2, 2004 08:51 PM
