Body/turn signal problem
Old Oct 1, 2011 | 06:19 AM
johnkilo3's Avatar
Default Body/turn signal problem
Hello, I purchased a 1999 GSR last week and the only problem with it body wise was that the driver side turn signal was cracked. Yesterday I went to replace it and when I took the old cracked one out, this piece of heavy plastic popped down. I'm guessing the car bumped something and slightly messed up the drivers side of the front bumper. It's making it impossible to slide in the new turn signal light. Yesterday I used a pipe as a makeshift lever to try and force it back up. While it did go back up, as soon as I moved the pipe it popped back down again. I didn't want to mess with it too much because I didn't know if this could possibly set off the airbags or something. Any ideas on how I can fix this?
Here are some pics of what I'm talking about.
Old Oct 1, 2011 | 03:11 PM
johnkilo3's Avatar
Default Re: Body/turn signal problem
No one?
Old Oct 1, 2011 | 03:21 PM
lazlong's Avatar
Looks like it broke off the back side of the bumper cover. Can you cut it off?
*Airbag system only has yellow wires.
Old Oct 1, 2011 | 06:29 PM
johnkilo3's Avatar
I was thinking about cutting it, we'll see I guess
Old Oct 1, 2011 | 06:42 PM
fcm's Avatar
fcm
Old Fart
Pull the clip off and see what that is, I do not see it... http://www.acuraautomotiveparts.org/...s=&view=normal
It does not look stock. 94
MrGiggles
Apr 14, 2011 12:53 PM
Showtime_III
Apr 8, 2005 04:52 PM
civileng25
Jul 21, 2003 09:17 AM
tND2k
Jul 15, 2003 10:59 PM
