Wink Mirror mounting In a Del sol?
Old Sep 30, 2011 | 08:46 PM
DohcSolz's Avatar
Default Wink Mirror mounting In a Del sol?
So ive looked all over honda tech and google combined for a write up of how people manage to fit 5 panel winks in a del sol.
The closet thing i find is a silver del sol with one, and theres a link on the how to but nothing comes up.
could anyone assist me or educate me with some sol literature?
Old Oct 1, 2011 | 05:22 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Wink Mirror In a Del sol?
I don't think space was the issue. The actual monting of one was. However I don't see how different it could be from a Civic and there's plenty of write ups on those. Time to get creative OP.
Old Oct 1, 2011 | 05:25 AM
N/A's Avatar
N/A
Purpose Built
Get one that mounts right to the windshield
Old Oct 1, 2011 | 08:04 AM
DohcSolz's Avatar
Sorry i shoulda been more clear, space is not the issue, its mounting. I had it rigged up ones with a flat piece of metal but it looked tacky.
Old Oct 1, 2011 | 09:11 AM
N/A's Avatar
N/A
Purpose Built
Then
Old Oct 1, 2011 | 09:56 AM
The Grumpiest
Get more creative.
Old Oct 1, 2011 | 12:02 PM
DohcSolz's Avatar
Thank you for all your help HT
Old Oct 1, 2011 | 02:48 PM
ervstr's Avatar
remove your stock review mirror, and screw the wink mirror on the top panel right by your windshield.its not like the civics where you can bolt it up to your stock visors.its pretty simple don't think to hard.
good luck bro
Old Oct 3, 2011 | 05:23 AM
barrett_5's Avatar
i may be wrong but i believe for the sol's you have to take off your visors to get it to mount properly (not for the window one obviously). may be wrong tho.
Old Oct 3, 2011 | 12:27 PM
D3vin's Avatar
Wink mirrors is one of the easiest DIY mods you can do to your car. It's as simple as replacing a shift boot. I have one in my EK and the mounts were direct fit. You need to take off your OEM visors in order to screw in the mounting plates and of course your OEM mirror. Then there is the issue of spacing and using spacers, longer bolts. You can find them in your nearest hardware store. Just mess around with it and don't force anything.
Old Oct 3, 2011 | 05:57 PM
The Grumpiest
If you searched you would have found this thread. I don't see anyone with a Del Sol having to do anything special to mount it.
https://honda-tech.com/forums/honda-acura-28/wink-mirror-2551170/
Old Oct 4, 2011 | 04:38 PM
DohcSolz's Avatar
im just looking for any tricks or clean ways maybe without drilling holes that someone has done it ON A DEL SOL.
Old Oct 4, 2011 | 11:09 PM
ervstr's Avatar
you can't see it from the out side that its drilled or can tell.but its the best way i could find with keeping the sun visors.but you can find the adapter that connects from your stock mirror.
Old Oct 5, 2011 | 03:43 AM
The Grumpiest
Grumblemarc in those three ive seen no pictures that help me whatso ever, i cant see any of their setups
buy a Broadway mirror instead. It just clips on.
Old Oct 5, 2011 | 06:38 AM
Former User's Avatar
Default Re: Wink Mirror mounting In a Del sol?
I deleted most off topic comments and posts in this thread. From here on out, please focus entirely on providing tech answers to the OP's question. Otherwise, don't post.
Old Oct 5, 2011 | 02:13 PM
DohcSolz's Avatar
i have a broadway right now lol and i guess im going to drill,
also thank you Ron!
Old Oct 5, 2011 | 05:43 PM
97dssi's Avatar
No need to drill. I used the sun visor screw to hold it in and be able to keep the sun visors. I took 2 different pictures to give you few ideas how it work. Hope the pictures work.
Old Oct 5, 2011 | 08:06 PM
DohcSolz's Avatar
i think i get it, when i get off tomorrow im going to try that thank you 97dssi!
Old Oct 5, 2011 | 10:38 PM
97dssi's Avatar
My first wink mirror was all messed up from the sun. So I bought another one. The brackets that came with wink mirror. I have 2 sets of bracket to make it hold perfect. So maybe go to ace hardware store or whatever to get maybe 3 inch bar to make longer bracket to hold the mirror or buy another set of wink mirror and use the bracket and have extra wink mirror with maybe stickers and stuff you like to add on wink mirror.
I added L shaped aluminum bar with JB weld on the back of wink mirror to prevent melting and bend the wink mirror. Then I add the house trim to make some cool style.
Old Oct 6, 2011 | 12:59 AM
taylorgang's Avatar
i just picked up one and installed it. pretty easy but just to warn you, the mirrors vibrate, not that bad tho.
Old Oct 6, 2011 | 03:19 AM
N/A's Avatar
N/A
Purpose Built
I can't believe your about to hack your car like that after I've informed you twice of an alternative.
Old Oct 6, 2011 | 08:22 AM
97dssi's Avatar
Yes it does vibrate but not all the time. It doesn’t bother me much.
Old Oct 6, 2011 | 06:32 PM
lazlong's Avatar
I believe the phrase was "Get one that mounts right to the windshield".
Hell, you probably could just epoxy the stock brackets right to the windshield.
If you want a clean look hacking up your car isn't it. Of course, you can always cover those horrible hack marks by covering them with small wire loom with dabs of sticky on the back.
Old Oct 7, 2011 | 05:02 AM
N/A's Avatar
N/A
Purpose Built
No.
They have wink mirrors that mount the same exact way as the factory mirror except it uses two arms.
You epoxy the metal tabs on the windshield and slide the arms on just like the stock one
And then your mirror wil be fully adjustable too. Not just up and down
Old Oct 22, 2011 | 08:28 PM
heyitzgrillz209's Avatar
I just removed the visors and screwed it onto the holes from the visors, I wish there was a headliner to cover up the holes. :c
Thorhammer
May 31, 2013 11:40 AM
trecool44
Jun 29, 2008 07:40 PM
vtec_r
Oct 11, 2003 05:16 AM
Guitarzann
Dec 24, 2001 05:52 PM
