Replacing radiator. Tips, advice, and a full report.
Old Oct 5, 2002 | 03:13 AM
rice_classic's Avatar
Default Replacing radiator. Tips, advice, and a full report.
I will be replacing my radiator with a koyo in my 88 si.
Any tips or hints are appreciated. I have a b16 and kept my a/c should this pose a problem?
After I am through I will post a report of the work and time and tools.
Old Oct 5, 2002 | 04:31 AM
xtrafastcivic's Avatar
Default Re: Replacing radiator. Tips, advice, and a full report. (rice_classic)
you'll probably need a thin fan...
Old Oct 5, 2002 | 10:02 AM
HF2ZC's Avatar
It shouldn't pose a problem. I've found that removing the fans from the radiator before you remove it makes it a little easier on a car with a/c. But, be careful when putting the fans back on with the radiator, it's pretty easy to punch a hole in the radiator.
Old Oct 5, 2002 | 02:54 PM
kyler's Avatar
Default Re: Replacing radiator. Tips, advice, and a full report. (HF2ZC)
yup,
also:
- drain is on bottom left
-clamp upper and lower hoses unless you want it dumping everywhere
-once the 4 10mm's are out just pull straight up and watch for any snags
it'll be easy enough for ya
NDNV
Honda Civic (2001 - 2005)
Mar 17, 2016 06:34 AM
Herbie
Nov 6, 2006 02:38 PM
BrokenRex
Oct 27, 2005 12:03 PM
vettman
Aug 5, 2005 06:07 AM
