exhaust flange vs ss band clamps?
Old Oct 5, 2002 | 01:40 AM
Norcalstoppy's Avatar
Default exhaust flange vs ss band clamps?
Are these 2 used for same purpose, connecting 2 pipes? or do they have a seperate unique usage?
jay Kim
Old Oct 5, 2002 | 07:54 AM
TimoneX's Avatar
New User
Default Re: exhaust flange vs ss band clamps? (AllMotorMonster)
SS band clamp? You mean like you'd use on your AEM intake to connect it to the TB? That will not work to connect 2 exhaust pipes. Even a heavy duty exhaust clamp can allow leaks unless the 2 pipes are mated nearly perfectly. A welded flange with a gasket is the best way to seal exhaust sections.
Old Oct 5, 2002 | 08:23 AM
ZetecOwns's Avatar
Default Re: exhaust flange vs ss band clamps? (TimoneX)
This one time, in band clamp... sorry guys I couldnt resist.
Old Oct 5, 2002 | 08:25 AM
lightning's Avatar
They are both meant to help join piping. If you have a "slip-fit" joint, the band clamp can work very well.
Old Oct 5, 2002 | 11:55 AM
Default Re: exhaust flange vs ss band clamps? (lightning)
So basically only for the pipes that line up, right?
Jay Kim
Old Oct 7, 2002 | 06:22 AM
lightning's Avatar
Typically on a slip fit joint, one pipe will slide within the other. If there is a gap between the pipes, I would not recommend the band clamp.
Old Oct 7, 2002 | 06:44 AM
sackdz's Avatar
Default Re: exhaust flange vs ss band clamps? (sohcvtecrx)
LMAO!
RACEPAK
Welding / Fabrication
16
May 7, 2005 07:34 PM
Vtec92Civic
Oct 20, 2004 02:07 PM
RCautoworks
Oct 18, 2004 10:37 PM
leeit2me
Nov 15, 2003 09:49 AM
technine
Apr 9, 2003 05:43 PM
