Kicker WX10000.1 amp
Old Sep 29, 2011 | 03:17 PM
s373n7s373n's Avatar
Default Kicker WX10000.1 amp
I have a 10,000 watt Kicker WX10000.1 amp for sale... yes I did say 10,000 watt... step up your game...lol. I am located in Ewa Beach Hawaii and will ship any were in the us except Alaska fully insured. It is brand spanking new opened only to take pics. Step up your game...lol I am asking 6000.00 or best reasonable offer and trades!
here are the specs:
Kicker Warhorse WX10000.1 Warhorse Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 5000 watts x 1 chan.
2 ohms: 10000 watts x 1 chan.
Max power output: 20000 watts x 1 chan.
Amplifies audio signal directly to DVC subwoofers from the patent-pending,signal-modulated power supply, rather than relying on help from amplification circuits found in traditional Class D or Class A/B designs
Wired remote bass level control included
LED power, remote, voltage, high pass/low pass, short circuit, and service indicators
Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
Planar Transformer Design
The WX amplifiers four (4) planar transformers are excellent for high power applications and are custom designed to handle 5,000 watts each, leaving more than enough power headroom to operate reliably and consistently at full RMS with 20,000 watts of total capability
Texas Instruments DSP
The Warhorse uses the latest Texas Instruments industrial grade DSP to handle the amplifiers pulse-width modulation, manage signal processing, and control the amplifiers protection circuitry
Insulated Metal Substrate Cooling
The Warhorse design uses insulated aluminum material for optimum heat transfer between power devices and the heatsink. Lower operating temperatures improve performance and durability while allowing for a smaller overall footprint.
Heavy Duty Industrial Bus Bars
The Warhorse has been outfitted with solid copper industrial grade bus bars. With 70 square millimeters of cross sectional area, the WX amplifiers heavy duty bus bars are specifically engineered to maximize the current carrying capability within the amplifier.
Super Thick, 4 Ounce Double Sided PCB
When you are livin this loud, you have to have a strong foundation. The circuit board used in the Warhorse is 50% thicker than the industry standard and uses the heaviest available 4 ounce thick copper traces and plated-through holes. This assures the circuit board can transfer the current needed for an amplifier of this magnitude.
Oversized Gold Plated Power Connectors
The Warhorse amplifiers gold plated power connectors were custom designed with multiple power terminals to maximize current carrying capability to the amplifiers signal-modulated power supply.
Industrial Grade AndersonTM Speaker Connectors
The 50 ampere AndersonTM connectors packaged with the Warhorse amplifier allow minimal contact resistance at high current. The housing of the connectors was designed to prevent polarity mismatches when connecting speakers and also protects fingers or probes from touching the metal contacts to provide additional safety from the high voltage signals coming from the voice coil (speaker) outputs.
Dual Thermostatically-Controlled Push-Pull
Cooling Fans Twin push-pull fans are mounted on the side of the amplifier to improve airflow and provide additional cooling for the amplifier.
Preamp RCA outputs
Low-voltage, high-voltage, filter bandwidth, temperature, and short circuit protection
Variable high-pass with subsonic (20-60 Hz, 24 dB/octave)
Variable low-pass filter (50-200 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-200 Hz
Dimensions: 35"L x 17-3/4"W x 3-3/4"H
dustinO
Northwest (Sales)
Mar 16, 2010 02:16 PM
jwm1986
Feb 5, 2010 08:07 AM
Aloha04MSM
Mar 22, 2006 07:46 PM
