Need help from a current TL-S owner!
Hi all.,
I don't currently own a TL, but I am using some parts from one.
I have a 2008 Civic Si. I am using TL-S wheels and want to use the TL-S Brembo calipers.
To fit the calipers, I need to use S2000 rotors.
Here is my question: How much room is there between the rotor and the back of the wheels?
On the civic, the caliper will be pushed out 6mm closer to the back of the wheel. Will this fit?
I can also put a 6mm spacer behind the rotor, but this requires longer wheel studs.
Can a current owner check this out for a fellow Honda/Acura enthusiast??
Here is a pic of the parts for reference.
ITR583
Feb 2, 2002 06:42 PM
