FS: Many parts stock and aftermarket!
Whats up HT, I got a ton of parts for sale, need the space back in the garage!
RC 550cc injectors - need new o rings have about 30k miles on them, sold the turbo set up without them. Looking to get $150 or trade for VIRGIN P30 ECU preferably JDM
Ebay Half Size Aluminum Radiator - Used for about 4 months comes with or without NEW apexi 1.3 bar cap. Also comes with electric fan mounted to it. Shroud is a little melted but still 100% functional. $70 with cap $60 without.
Stock Half Size Radiator - In good shape works perfectly fine $20
A/C system - comes with all the lines, condenser (with fan and shroud), wiring and relats, dryer, etc. Only thing you need is an evaporator. Compressor is included and is believed to be in good condition pulled it out of my boys eg and it was blowing a little cold but its needs all new o rings (10 bucks online) so it doesn't leak and it should work fine. Looking to get $100 for everything OBO
Granny Apple Green Powder coated LS valve cover - In good shape, only on the car for about 5 months. locked up the B18 so I got no need for this. $100
Newer Style LS valve cover - Mostly stripped but has some paint on it $30
Older style LS valve cover - Wrinkle black but part of it painted green $30
B18a1 intake manifold - $25
B20 intake manifold - Inside has oil residue but assuming it can be cleaned $25 obo
Honda B series block fittings for catch can - $30
Ebay Oil catch can complete barely used - $25
OBD1 LS dizzy - $30
ABS Pump - $30
Power steering pump and reservoir - Works perfectly fine $30 Add $10 for the brackets
As you can see my prices are very reasonable but I am a little flexible on certain items. I will have more pics up tomorrow had these on the computer already though. txt/call me anytime at 516-993-8991 - Ricky
I know its not engine related but I have a set of del sol door panels with tweeters, no window switches, letting them go for $25 for the pair! Have the infamous wrinkles on both sides but other then that they are CLEAN
OBD1 LS dizzy - $30
ABS Pump - $30
2000turbosi
Dec 22, 2011 04:09 AM
92000HaTcH
Northeast (Sales)
23
Oct 28, 2009 06:39 PM
ALL IMPORT
Jun 29, 2008 05:01 PM
IntegraKarim
Jun 20, 2007 10:08 AM
