Help sourcing a bumper bolt for a 94-97
Basically, there is this mudflap that is attached to the bottom portion of the 94-97 bumper. It is held in my 2 bolts (I believe) and I don't know where to get them? i might just go to a junkyard but I would be easier for me to just order from honda.
I reversed my car on a lawn (and my car is low) and the grass literally pulled the black mudflap forward like a sore tongue....
Here is a pic, I *BELIEVE its 33.... Not sure tho.
EDIT: Okay, doesn't look like its 33 anymore. That looks like the bolt that attaches the upper portion to the lower portion..... I edited the image and circled the black mudflap in red. Does this hang freely or is there a way of mounting it so it doesnt stick out? Mine is so bent out of shape that it basically just hangs down. It looks awful and scrapes on EVERYTHING!
Ditto that^^^, I installed longer 10mm bolts and spacers so I could attatch my front "wing" to the same place as the "mud flap" is attatched, you can get the bolts atany hardware store, [10mm ISO].
If you want, send me a pre-paid/addressed envalope and I will send you the original ones out of my 94. 94
Cut it off..lol.I had a teg that kinda had it bent downwards and it kept catchin goin out driveway.
Put the Bolt and it still came off..finally got pissed and trimed it up cuz I got tired of trying to make it stay.
Their list of part numbers skips #33
32 xxxxx-xxx-xxx
34 xxxxx-xxx-xxx
So I doubt they will be able to look it up.
But knowing its a 10mm thread pattern, I can just go to any store and get one that fits. Thanks guys!
If you go to a hardware store it would be a M6x1.0 bolt. As for length I'd grab one about 30mm long and a big washer to go with it. 10mm would be the size socket you'd use to tighten it down.
Aah thanks. Forgot that honda uses the metric bolts. Alright Ill go grab 2 of these, thanks!
If the number is skipped on this particular drawing, it'll show up on a different one. There's no way that an Acura dealership wouldn't be able to look up the part #.
. O M E G A
Oct 17, 2005 01:45 PM
