Parting out H23 Blue Top Track CR-X
Old Sep 28, 2011 | 07:59 PM
Morning Pirate's Avatar
Default Parting out H23 Blue Top Track CR-X
I have for sale these items listed below. I'm located in Marysville, WA.
  • $1,500 H23A Blue Top VTEC Engine (Dynopack tuned to 214.5 whp / 178
    ft lbs), timing belt changed 6,000 miles ago, roughly 36,000 miles on engine,
    auto to manual timing belt tensioner installed
  • $400 P06 ECU Chipped and tuned on Crome 1.5.5 for VTEC, launch
    control
    set at 3800rpm, rev limit set at 7500rpm, fuel cutoff set at 7800,
    shift light set as check engine light at 7500rpm great tune from
    Speed Factory Racing
    AND CR-X engine harness with adapters for OBD1 ecu
  • $600 T2T4 transaxle (factory LSD equipped)
  • $200 Custom axles from Raxles for H series trans in CR-X Si hubs
    (including mid shaft)
  • $100 Chromoly 9lb flywheel
  • $300 ACT "HA3 - HDG6" Ceramic 6 puck sprung hub clutch w/355ft lb
    pressure plate
  • $150 ExplicitSpeedPerformance H series engine mounts for EF chassis,
    cable to hydro conversion bracket, and alternator bracket
  • $200 ExplicitSpeedPerformance EF traction bars
  • $250 Tokico Illumina 5 way adjustable struts
  • $150 Ground Control "4525custom" 430lb F / 350lb R (for slight
    additional weight of H series engine) along with the Tokico struts
    this is a great setup
  • $250 Precision 580cc injectors
  • $400 Rosko Racing Euro R intake manifold ported and polished, w/block
    off plates
  • $15 Short (GSR) intake tube and cone style filter
  • $100 H22A4 4-2-1 header (also fits H23A VTEC engine) ceramic coated,
    also includes new catalytic converter
  • $400 Thermal R & D 3" chrome exhaust
  • $120 Odyssey "PC680MJ-A" metal jacketed light weight dry cell battery
  • $50 Jegs Push Pull type 300A battery kill switch
  • $50 Walbro 255lph Fuel Pump
  • SOLD$50 DA Integra rear disk brake conversion, includes everything; trailing
    arms, stabilizers, disks, calipers, e-brake cables, and bushings
  • $10 Nearly brand new OE CR-X Si front brake pads / DA rear pads
  • $600 1 month old Kosei K-1 15x7" 4x100 wheels (1 has small lip scuff, 1
    has some curb rash) wrapped in 90% treadwear Dunlop Direzza
    Sport Z1 Star Spec 195/50R15 (great 200 treadwear traction)
  • $60 Semi gloss black C type harness bar (support beams cut and
    welded to fit factory rear seat belt bolt location)
Please PM me with any questions. The engine and trans are currently in my CR-X running and driving excellent.
Thanks for looking.
Old Sep 28, 2011 | 08:04 PM
JDM_rolex's Avatar
Default Re: Parting out H23 Blue Top Track CR-X
Pmd
Old Sep 29, 2011 | 08:04 AM
Bump
Old Sep 29, 2011 | 08:26 AM
thundernoodle's Avatar
where are you located?
Old Sep 29, 2011 | 09:06 AM
Marysville, WA
Old Sep 29, 2011 | 08:01 PM
Evening bump
Old Sep 30, 2011 | 11:26 AM
Lunch time bump
Old Sep 30, 2011 | 05:32 PM
I priced everything really cheap. Please feel free to offer a price on anything.
Old Sep 30, 2011 | 11:03 PM
Bedtime bumping
Old Oct 3, 2011 | 10:35 AM
Would you ship anything?
Old Feb 13, 2012 | 11:21 AM
gueryroy1's Avatar
interested on the h23a engine if u still have it 4 sale call me at 347-444-6558
Old Feb 13, 2012 | 07:03 PM
lukeb89ef's Avatar
pmed
kekekekevin
Jul 15, 2007 11:43 AM
Twilightepitaph
Aug 15, 2005 08:15 AM
VtecKiDD
Mar 8, 2005 06:47 AM
darkstarsi
Jun 19, 2002 12:50 PM
