Touch Up Paint
Old Sep 28, 2011 | 05:26 PM
curtie94's Avatar
Default Touch Up Paint
I have a 1991 Honda Accord with a cracked rear and front bumper and some rust on the wheel wells, plus a nice rust scratch on the bottom of the passenger door. I want to do some bondo work and remove the rust and paint chips. I am going to use duplicolor paint as my paint. My only question is what kind of sanding should I do, what kind of sandpaper should I use? How many coats should I do of primer, paint, and clearcoat.The wheel wells where already bondoed and primed but rust is coming back through can I just sand it back down and re-bondo and prime then paint.
These Picture are a little older.
I got this car for $500 and have just been chipping away at the problems.
Old Sep 28, 2011 | 05:39 PM
Openclutch's Avatar
Default Re: Touch Up Paint
i had to paint a fender cuz my wheel fell off :/. grabbed one from the junk yard sanded it down 2 coats of primer. 3 or 4 coats of paint. 2 coats of clear. looks not to bad but it seems the clear i got was garbage.
Old Sep 28, 2011 | 06:16 PM
curtie94's Avatar
Did you sand in between paint coats as well?
Old Sep 28, 2011 | 08:16 PM
justin123560's Avatar
For repairing my bumper I used very fine sand paper like 1000g - 2500g. It depends how bad the bumper is. To prime it you should apply light coats then sand it. Sand between coats and increase the grit of the sand paper as well.
Old Sep 28, 2011 | 10:38 PM
75aces's Avatar
Did you use a cleaning solvent in between? What about a scouring pad? The metal needs a key for it to stick to the fender. How bad is the rust? Does it look like swiss cheese? If it does, you're better off making a patch panel and then weld to body. After that bodo over it. Sand and sculpt to final shape. If you just bondo over rust, it'll just keep coming back.
Old Sep 28, 2011 | 11:08 PM
75aces's Avatar
http://www.popularmechanics.com/cars...enance/2763656
Diy bumper repair.
Old Sep 29, 2011 | 05:39 AM
StreetsideStig's Avatar
That thing's in darn good shape for a $500 '91. Good find.
Old Sep 29, 2011 | 07:09 AM
curtie94's Avatar
no I didn't clean in between layers, and we did ruff it up a little. The primer is chipping on the rear bumper and the wheel wells have rust bubbles that when you push them they pop out water.
Old Sep 29, 2011 | 11:39 AM
75aces's Avatar
Can you post a better picture of the area that is rusted with the bubbles? That may be the beginning of the body cancer. Have popped all of the bubbles? If you clean the panel after sanding, you will remove most of the contaminants. May need to sand back down to bare metal and redo. Do you have any holes in the rusted area?
Old Sep 29, 2011 | 01:16 PM
curtie94's Avatar
heres the rust bubbles coming though the primer
Heres the rear bumper
Heres the door
And the dent on the back panel
How is the best way to pop this kind of dent out?
Old Sep 30, 2011 | 11:55 PM
75aces's Avatar
For the rear bumper, have you considered getting another bumper? Might be much cheaper because you won't have to repair it before painting it. The dent on the rear panel doesn't look too bad. Pull the panel off inside the car to see if you can use a hammer and a dolley. If not, do you know someone with a stud gun? With the stud gun, you can get rid of most of the low spots and use bondo to make it even. The rust bubbles look pretty bad. I would recommend making a patch panel. Is the inside of the wheel well rusted also?
Old Oct 1, 2011 | 08:59 AM
curtie94's Avatar
How would I get the panel off inside the car, i've loooked and can't find any fasteners or anything.
FishyMan
Paint and Body
Feb 28, 2009 06:17 PM
hamadiscool
Jun 12, 2006 04:18 AM
1995silverinteg
Mar 25, 2004 12:45 PM
XDEep
Mar 9, 2004 07:56 AM
