86 CRX Sunroof Motor
I think a junkyard or pick n pull would be your best bet or completely get rid of your sunroof by swapping roofs. They are kind of a pain in the *** to get out though so you might have to pull one yourself.
I don't think the motor would be too hard to overhaul. Probably the same as a starter overhaul. It'd probably cost you more if somebody else does it. Might only need new brushes soldered on. Keep the old one as a back up and try.
