car makes grinding noise when turn on 2nd time
Old Sep 28, 2011 | 02:52 PM
panchlow's Avatar
Default car makes grinding noise when turn on 2nd time
integra ls.
jst bought this car a week ago and every time i run the car for a while or jst fast and then try to turn it on again it turns on but the idle goes down then it dies on me and wen i try to turn it on again it makes a grinding sound... :/ but it finally turns on...
no cel.
n0 grinding 0n gears 0r p0p 0uts.
Old Sep 28, 2011 | 04:24 PM
Manny 77's Avatar
Default Re: car makes grinding noise when turn on 2nd time
Where's the grinding coming from??? Shutting off I don't think has nothing to do with the grinding noise unless your engine bottom is giving up
Old Sep 28, 2011 | 05:40 PM
1998GsRIntegra's Avatar
You sure it just doesn't act like its dying? Then as a result, you hit the starter again and it grinds on the flywheel. That would be my guess.
Old Sep 28, 2011 | 06:05 PM
hondalike's Avatar
The grinding as you describe is definitely your starter grinding on the flywheel. The person you bought it from probably had a bad starter and let it go until it chipped some of the flywheel teeth. Do an inspection of the flywheel and starter or have someone do it. It shouldn't be too expensive to get it checked. The sooner the better.
Old Sep 29, 2011 | 10:52 AM
panchlow's Avatar
yea i was guessing it was the flywheel, but idk if this causes the same thing but when i was launching it and i was at 7mph and i let go of the clutch it was jerking and i couldn't go to any higher speed cause of the jerk. Then when i came to a completely stop it just died on me.
Old Sep 29, 2011 | 12:23 PM
hondalike's Avatar
See this recent thread https://honda-tech.com/forums/acura-integra-6/step-gas-pedal-then-dies-2983845/ . One of the functions of the TPS is to let the ECU know if you're letting off on the throttle because the ECU will then shut the injectors off. Sometimes the TPS will cause a feeling like the fuel pump is shutting off at certain throttle positions when it goes. Unfortunately it could also not be that and will require more research, maybe a Helms manual and some tools. In the end it may be cheaper for you to take it somewhere, sorry.
Old Sep 29, 2011 | 09:32 PM
panchlow's Avatar
^ thats sum what 0f what it d0es.
t0day i checked.
started - g00d
flywheel - g00d
battery - bad. but replace and still did it.
fuel pressure - g00d.
distrubit0r- g00d.
we did the timing nd still did it.
s0 n0w I'm thinking i still have t0 clean anything d0 with air...
any 0ther suggesti0ns??
-thanx f0r all the help
Old Oct 1, 2011 | 03:47 PM
panchlow's Avatar
bump!
still need help.. i jst change my spark plugs bcus the lookd old but it still did it..
i change my tb from my hatch to the integra.. i bolted on right nd it didnt stumble when i was accelarating so i thought i fixed it.. it wasnt that either
bcus it did it in the morning..
what else can i check??
my friend said the fuel injectors might be clogged.
help...!!
Old Oct 1, 2011 | 03:49 PM
panchlow's Avatar
ps.. it wen i accelarate it gets stuck on a rpm nd u hear bubbles coming from the exhaust nd it wont accelarate... it car is jerking when its doing that.. like if i didnt let go of the clutch right.
Old Oct 1, 2011 | 07:07 PM
Hidenplanvew's Avatar
why do you spell everything with a 0 and not a o? Bubbles... Its miss firing or running rich... sounds like you dont know much about cars, I would take it somewhere
Old Oct 1, 2011 | 07:23 PM
panchlow's Avatar
wen i use my laptop my keyboard is broken..
so instead of using o i use 0..
Old Oct 2, 2011 | 08:01 AM
Well at least you have a reasonable explanation for it.
At this point I would just take it to a mechanic. Its extremely difficult to diagnose something over the internet. Especially with the details your giving that most of us have never heard used before to describe a problem with a vehicle.
Is it possible for you to take a video of the problem occuring and post it?
Old Oct 2, 2011 | 08:15 PM
panchlow's Avatar
yea its hard to explain.
ill try to get a video..
ddh052286
Feb 20, 2011 07:22 AM
bmilt*336
Apr 29, 2010 05:06 PM
fcjohnny
Oct 27, 2009 06:49 PM
meanshyguy
Sep 1, 2009 07:42 PM
TylerC161
Dec 29, 2007 11:21 PM
