will any 18 inch tire fit on any 18 inch rim?
Old Sep 28, 2011 | 10:14 AM
my94d16y8coupe's Avatar
Default will any 18 inch tire fit on any 18 inch rim?
ok so the deal is i have a set of 18 inch wheels with brand new tires, the downfall is one is dented and another is cracked. The tires are brand new and the size is 215/35/r18's. My friend is selling me is 18 inch rims because they need new tires. but the tires he currently has on them is 240/45/r18s. will my tires fit on his rims? thanks
Old Sep 28, 2011 | 10:27 AM
toyomatt84's Avatar
Sanji
Default Re: will any 18 inch tire fit on any 18 inch rim?
No, tires are rated for a certain range of wheel widths.
215/35/18 - rated for 7" - 8.5" wide wheels
245/45/18 - rated for 7.5" - 9" wide wheels
Old Sep 28, 2011 | 11:03 AM
will the 215/35/18 tires fit on a 225/40/18?
Old Sep 28, 2011 | 11:38 AM
toyomatt84's Avatar
Sanji
Huh? You cannot put a tire on top of a tire. Like I said before, the wheel width is determined by the tire size.
Old Sep 28, 2011 | 11:58 AM
i mean a rim with a 225/40 tire on it. how do you know the tire widths by the numbers? is there some kind of calculation done?
Old Sep 28, 2011 | 12:18 PM
Drive 4 fun's Avatar
What is the actual wheel width he has? Looks like from the post above an 8" wide could work for either,and also 7.5 or 8.5. It should say 18 x W on the rim which is better than a measurement unless you know how/where to mearure.
Old Sep 28, 2011 | 12:31 PM
doc@tirerack's Avatar
If your friend's wheel is between 7.5" and 8.5" you are fine (as mentioned above). The width of the wheel should be stamped on the back somewhere, so its worth a look before buying
Old Sep 28, 2011 | 12:54 PM
toyomatt84's Avatar
Sanji
The specifications I listed are given by the manufacturers of the tires, as to their regulated limit of wheel width. You need to find out the wheel width, as the tire width really doesn't mean much.
And, where did you get this 225/40 tire? Your story is very inconsistent.
Old Sep 28, 2011 | 03:28 PM
sorry the 225/40 are enkies i just bought off craigslist for $380
needed new wheels pretty badly. and ill see how wide they are
Old Sep 28, 2011 | 03:32 PM
ok so both rims say 18X7.5 on the back of them so im pretty sure theyll fit
rc2o6
Northwest (Sales)
Dec 12, 2010 06:07 PM
mac_24_seven
Apr 5, 2007 04:46 AM
honda_andy
Nov 20, 2006 09:30 AM
BuyImports2
Mar 19, 2005 04:35 PM
CoolKat
Jul 24, 2002 10:22 AM
