Classic Hondas All Pre-1988 Hondas.
87 Civic 1300 1.3L.. interface or non-interface
Old Sep 27, 2011 | 12:49 PM
urallsafe's Avatar
Default 87 Civic 1300 1.3L.. interface or non-interface
My son bought a 1987 Civic with 1300 1.3L engine. Has over 150,000 miles. Recently the timing belt broke while he was on freeway. He thought fuel pump went out (limited driving/car issue history) so forced it .5 miles to off ramp, then attempted to start it so many times battery died.
When I got to check it out, clearly more than fuel pump and no compression so assumed timing issue. Towed it to where we could work on it. Replaced timing belt with little difficulty. Note: there was no clear indication for TDC on the camshaft gear. The hash marks for leveling gear with head where clear but no "up" indicator. One side had an OEM hole in gear, the other side had numerical markings stamped into it. We used stamped side as TDC.
Upon starting, there was immediate evidence of an issue. Missing and dies unless gas pedal is actuated. Sounds like compression is just behind where it should be... as in missing, but with good detonation.
It seems like maybe the camshaft could be 180 degrees off OR the valves and/or valve rods were damaged.
Any input on the above is helpful, plus I'm seeking answers to these questions...
1) Is this motor interface or non-interface?
2) If the camshaft gear was 180 degree off on installation would these symptoms be present? Would the vehicle even run?
3) There is leaking now from what seems to be main seal, is this common and do you agree that leaking oil may have caused the belt to fail in first place?
4) If we have to rotate the camshaft gear 180 degrees, we will have to r&r the belt anyway and will replace the main seal at same time... any input on that process to avoid mistakes?
5) Will take any and all input on this situation
Thanks,
Mike
Old Sep 27, 2011 | 01:06 PM
urallsafe's Avatar
Default Re: 87 Civic 1300 1.3L.. interface or non-interface
So I just looked under the hood and it says..
On engine...
DR485-34
7103
under hood label...
1300
HHN1.5V3EBC6
82 in displacement
so... maybe this is a 1300 1.5L?? This is pretty confusing, any help/input may help
Old Sep 27, 2011 | 02:09 PM
TunerN00b's Avatar
On engine...
DR485-34
7103
under hood label...
1300
HHN1.5V3EBC6
82 in displacement
82 in^3 is 1.3 liters
Google unit conversion: http://www.google.com/search?q=82+in^3+in+liters
Old Sep 27, 2011 | 02:28 PM
urallsafe's Avatar
Yes I thought that too but what is the 1.5v in "HHN1.5V3EBC6"?
And do you have answers to the other questions, particularly if it is interface or non-interface... if non-interface there may be not great damage.
I found a site that lists known "interface" engines and the 87 1300 1.3L isn't on it... I'm just looking for an easy route, I know I know it's not just so simple but info will help me.
Old Sep 27, 2011 | 03:27 PM
urallsafe's Avatar
Nevermind folks... it's not worth pursuing... for sale in San Jose, CA area if interested
Old Sep 28, 2011 | 12:02 PM
Gustav129's Avatar
In the US, the 87 didn't come with a 1.3L. Must be in Canada...
AFAIK, all Honda engines are interference engines. Did you pull the head and do and inspection?
When I rebuilt my 1.5 years ago, there's a dot and "Up" (not arrows) Sounds like you may be off a tooth. Does it tick? Any more than a tooth off, you are destroying valves.
Kevin_8
May 5, 2015 04:36 AM
thekeysarebroke
15
Oct 1, 2012 05:35 AM
civicmidwest_08
Jun 25, 2008 01:10 PM
dopefeen
May 7, 2007 08:23 AM
intezn
12
May 17, 2003 11:48 AM
