Car Heat Only Hot on Low Fan Speed
Ok well its getting colder here and all last winter I had barely any heat from the same issue, I have no idea what is the issue. When I put the heat on and fan on low it is as hot as I can get it, if I put the fan speed on any higher the air is cold. I've attemped to backflush the heater core but I haven't put any cleaner in there.
The fan works at all speeds.
Car is a 1991 Honda Accord 2 DR LX with 167,000 miles
It is no fun driving with no heat.
Are you sure the temp **** is turning all the way to open up the valve to the core? They are famous for getting sticky. When I installed a new Cd player into my 95 Accord I made sure to lube that up while I had that panel off. Several times It has gotten to the point of when you turn it to full hot or cold it wants to spring back to the middle.
Yeah I already changed the thermostat when i replaced the radiator.
The **** does seem to want to sprang back, the only way I even get close to sufficient heat I have to really turn the **** and it clicks otherwise it wants to spring back i'll try to lube that up.
My 91 accord does something similar, to get the heat all the way on 'hot', I have to manually reach down and flip the linkage to open the core. get in there and move it back and forward a few times and make sure it has the travel it needs. I think its about 1/4 turn (theoretically- if you could turn it in a complete circle(you cannot))
No the water valve opens up with no problems and the heat **** moves freely now, but still the same issue. The outlet hose from the heater core is not anywhere close to as hot as the inlet, could there be a clog in the heater core?
JigsN Joints
Aug 18, 2011 12:32 AM
EFOwNzALL
Jun 24, 2008 09:09 AM
