B18C rev limits then limp mode ONLY when humid/rain
Old Sep 26, 2011 | 02:21 PM
royalmustard's Avatar
Default B18C rev limits then limp mode ONLY when humid/rain
Hello everyone.
I have a 1994 Civic Hatch with a B18C1 swap. Recently I started noticing that when its 1am or so, when dew settles on the car and the air is moist, my car will hit a rev limiter between 5-6.5k rpms then go into limp mode (wont rev past 3k). There is a cel but it has always been there, its just an O2 censor thats not there anymore. I turn off the ignition, turn it back on, and everything is back to normal. Until I tap the rev limiter again.
When conditions are dry the car will rev to 8k in all gears like its supposed to.
I have no idea where to begin so any insight or advise would be helpful.
Thanks a lot.
Old Sep 26, 2011 | 03:07 PM
kchungb17a's Avatar
Default Re: B18C rev limits then limp mode ONLY when humid/rain
Double check the ECU for DTC's. Jump the connector and count the blinks. That's the best place to start. You may find that it is not just an O2 sensor code that you have.
How's the oil level?
Old Sep 26, 2011 | 03:59 PM
fcm's Avatar
fcm
Old Fart
Check the distributor, [inside] for moisture, make sure the cap gasget is in good shape, #9... http://www.acuraautomotiveparts.org/...s=&view=normal 94
Old Sep 26, 2011 | 04:41 PM
I don't know what you mean by "Jump the connector and count the blinks." However the oil level is right where it should be, I always make sure its good on oil as it tends to burn some.
Old Sep 26, 2011 | 04:42 PM
I will look into this tomorrow in the daylight. Thanks for the reply.
Old Sep 26, 2011 | 05:25 PM
kchungb17a's Avatar
Try this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Sep 26, 2011 | 05:31 PM
Thank you!
Old Sep 28, 2011 | 06:27 PM
The distributor had some moisture inside. I dried it out as best I could and sealed it off better. The problem seems to have stopped.
Old Sep 28, 2011 | 08:09 PM
fcm's Avatar
fcm
Old Fart
Replace the gasket it's only about $5
If there was moisture in the cap then there was moisture everywhere in the distributor, [all connections to the coil and IGM] oxidization WILL happen.
If it was my car I would pull the coil and ICM, clean and dry them and clean the terminals, make sure the inside of distributor was clean and dry, spray contact cleaner on all the teminals and connectors, reinstall the coil and ICM and unless cap and rotor are in good shape, replace them along with the new gasket.94
Old Sep 28, 2011 | 08:43 PM
backman_66's Avatar
I had a similar issue with my B18C1 when there was moisture and humid. Replacing dist. cap / rotor fixed mine as well. Gotta make sure that's sealed up. Moisture is baaaad news.
Old Sep 29, 2011 | 09:55 PM
Thank you for the advice. Will do!
Old Sep 29, 2011 | 09:57 PM
I was beginning to think I was the only one this has happened too, haha. Everyone I talked to about it had no idea... This forum has been very helpful.
the king.
Jan 10, 2009 05:42 PM
lutronluvinek9
Mar 5, 2007 11:50 AM
jdmhatch10
Oct 23, 2005 09:43 AM
93si-hybrid
Jul 23, 2005 03:10 PM
Xlerate9
Aug 26, 2003 01:45 PM
