Help me diagnose why my 93 Accord runs like donkey.
Old Sep 26, 2011 | 08:57 AM
Erics 96 NSX T's Avatar
Icon6 Help me diagnose why my 93 Accord runs like donkey.
Just bought a 1993 Accord LX with Auto Transmission, has 161,000 miles. I noticed it had a misfire/stumble at idle but bought it thinking a simple tune up would help. My check engine light is NOT on..
This weekend, I changed the Plugs, Wires, Cap and Rotor. Didn’t help at all.
I has a pretty bad miss/stumble at idle and one around 2500 rpm’s, then it clears up in the higher rpm’s. It seems the miss is worse while in reverse. Might be my imagination but thought it would be worth mentioning.
Anything big that I’m missing?
Old Sep 26, 2011 | 08:59 AM
Default Re: Help me diagnose why my 93 Accord runs like donkey.
FYI, it idles around 800 rpm's.
Old Sep 26, 2011 | 09:01 AM
Steve Z's Avatar
Off the top of my head without seeing or hearing it, I would guess that your EGR ports are clogged up. That stumble is symtomatic with those ports which are located under the fuel rail, being clogged or blocked with carbon looking gunk. There is an Eric the car guy video on how to do that job which might be found in the FAQ section?
Old Sep 26, 2011 | 09:02 AM
nwf_snake's Avatar
EGR or IAC Valve problems would be a good start.
Old Sep 26, 2011 | 09:08 AM
I was screwing around this morning and I unplugged the Hose going to the EGR Valve, no change in idle. I also unplugged the electrical connector going to the EGR Valve. Still no change.
What else should I check with that EGR Valve?
Old Sep 26, 2011 | 09:09 AM
I've had IAC problems on other cars before, wouldn't that just cause surging and idle dropping when accesories are on?
Old Sep 26, 2011 | 10:12 AM
redbull-1's Avatar
EGR ports.
http://home.comcast.net/~em-engineering/T2T013.pdf
Old Sep 26, 2011 | 12:04 PM
So, how would a EGR cause the engine to run like ***?
Old Sep 26, 2011 | 12:11 PM
redbull-1's Avatar
I'm not saying it may be the actual reason your car is running like the way it is; but, posters were referring to the EGR ports as a possible cause instead of the EGR valve.
Quote from link:
"Some, or all of the 4 EGR runners in the intake manifold clog up. The rough running apparently comes from some ports clogging and all the exhaust gas being fed to the working ports and causing them to have too much exhaust and consequentially cause them to misfire."
Old Sep 26, 2011 | 01:05 PM
jdmcertified909's Avatar
is the check engine light on? if it is you can jump it from a 2wire plug thats behind the kick panel in the passenger side. a blue plug with two wires. jump it and turn on the key to II and watch the check engine light flash. shoud give you a code. check youtube on how to do it. when you get the code post it here. so we can help you. remember a code doesnt tell you whats wrong with it. it just help find where the problem is futher diagnosis will help find the problem
Old Sep 26, 2011 | 04:17 PM
The Check Engine Light is NOT on.
Old Sep 26, 2011 | 04:37 PM
Still worth a shot it might have came on one time and you never noticed. It,would be stored in the ecu. So jump it and see what it gives you. Never know.
Old Sep 26, 2011 | 04:51 PM
One more important thing, when I pull the drivers side plug wire. There is no change in idle.
Old Sep 26, 2011 | 08:56 PM
holmesnmanny's Avatar
That helps isolate it to one cylinder however it could just be that that egr port is clogged up.
Old Sep 27, 2011 | 06:21 AM
Steve Z's Avatar
Bingo!
Old Sep 27, 2011 | 09:59 AM
So, what is the easiest way to check my EGR Ports?
Thanks ya'll.
Old Sep 27, 2011 | 02:40 PM
Steve Z's Avatar
Check under the FAQ section of this forum. I believe there is a step by step how to do this job. In short, it requires removing the fuel rail. The ports are located under it. I found it. Here ya go.
Old Sep 27, 2011 | 06:27 PM
justinsbg's Avatar
Thanks ya'll.
I wouldn't think that the EGR ports being clogged is causing a misfire at idle, not to say they aren't clogged. The basic reason cylinders misfire when the EGR ports are clogged during EGR operation is the fact that instead of the gases being distributed evenly to all cylinders, the gases are then dumped into 1 or 2 of the cylinders causing a Lean Misfire. There are a few ways to check for port clogging. One, you can use a vaccuum gauge and pull a vaccuum on the EGR valve to open it and allow full flow to the intake through the valve. If the engine doesn't stall or run really rough then the ports are fine. Another way, is put the car in gear with your foot on the brake and raise the RPM's to about 1500. This should cause the EGR valve to open. If the engine sputters while you have the RPM's raised then the ports are clogged and need to be cleared. If I were you, I would focus on the #1 cylinder which would be the plug wire closest to the timing belt/driver's side.
Old Sep 28, 2011 | 09:24 AM
Steve Z's Avatar
Good post and makes good sense. He did state that he changed the plugs and wires, cap and rotor, so possibly that plug wire is defective or (like some new wires sets) he needs to make sure that the wire is pushed all the way into the long connector and getting spark on that plug.
Old Sep 28, 2011 | 02:50 PM
The wire is good, I swapped them with no change.
Old Sep 28, 2011 | 05:41 PM
justinsbg's Avatar
Have you pull the spark plug out to make sure the tip isn't bent or distorted in any way? It sounds simple, but I've seen it many times. If it's only #1 cylinder causing problems you need to figure out what's missing in #1. Is it spark (probably not being that you replaced the ignition parts), Fuel, or compression? Have you run a compression test on the cylinders? Try taking a long screwdriver and putting the tip of it to the base of the injector where it mates to the intake. Once you've done that, listen to all the rest and see if you notice a change in sound of the injector pintle opening and closing.
Old Sep 29, 2011 | 10:05 AM
The plug is good, so was the old one. It's getting spark. I haven't checked for compression or injectors although when I pulled the plug out, it was noticably drier than the rest. I'll try the injector trick.
Will the clocked egr port cause a change in compression?
Old Sep 29, 2011 | 11:34 AM
No becuz your at idle the egr doesnt open until 30mph I believe. So no it doesnt. Im leaning more towards the injector. If it was the rings that were gone on that cylinder your spark plug would be soaked in oil. So just check out the injector. Try hitting it with a screw driver gently to see if you can get it to budge. If it doesnt I would recommend changing your fuel pump strainer clean out your gas tank new fuel filter new injectors and clean out your fuel lines
Old Sep 29, 2011 | 01:54 PM
justinsbg's Avatar
If there is low compression it doesn't necessarily mean that the rings are worn. He could have carbon build up on the intake valve(s), I've seen that many times. He could also have intake/exhaust valves not sealing either because they're burnt or bent. I would definitely try a basic compression check.
Old Sep 29, 2011 | 02:19 PM
exactly if seals are worn on valve or damaged seals at the valves it would throw blue smoke out the pipe due to it burning oil. And if valves were burn or bent it would misfire alot bit in his case it doesnt make ANY diff when he disconnects that plug
